Creating an custom BOM table with view representations
jaco011
jaco011
Hi all,
I hope someone can help me in the right direction.
We use View representations to create (color) variants. And with iLogic we create an BOM with custom table.
The current base of the code is place below. I stripped all the exceptions / renaming based on view representation name, creating tables, etc. because that works fine.
The problem I encounter is that to get the 'associated' view representations of subassemblies I need to activate each view rep. Which means that inventor wants to save all the (sub) files. Also the ones blocked due to the vault.
Is there a way to read all the view representations and their information, without the need to activate?
I found;
Dim DesignInformationString as string = oAssyDoc.DesignViewInfo
It works doesn't need the activation, which is great. But it gives colours, instead of linked design views and their names. It also ignores the assembly layers, and goes straight to the leaf occurences. (I Need the assembly's, unless they are phantom)
Sub Main
	'Bestand definities
	oAssyDoc = ThisDoc.ModelDocument
	oDrawDoc = ThisApplication.ActiveDocument
	oAssyDefinition = oAssyDoc.ComponentDefinition
	EachViewRep
	MessageBox.Show(EndResultMessage)
End Sub
'Definities voor gehele rule
Dim oAssyDoc As AssemblyDocument 'het assembly bestand
Dim oDrawDoc As DrawingDocument 'het drawing bestand
Dim oAssyDefinition As ComponentDefinition 'definition van het assembly bestand
Dim ViewRepName As String 'huidige view rep naam
Dim EndResultMessage As String 'bericht op eind van code
Dim CurrentVariantTable As String 'tabel van huidige variant
Dim AddToList As String 'string voor toeveogen infomratie aan lijsten
Dim BOMList As New ArrayList() 'per variant: stuklijst
Dim PhantomAssemblyPart As Boolean 'bijhouden of deze assembly/part phantom is of niet
Dim ModifiableBoolean As Boolean 'controlere of assembly aanpasbaar is
Sub EachViewRep
	'Definities binnen sub
	ViewRepName = "" 'Name van view rep
	Dim oViewReps As DesignViewRepresentations 'meerdere view represetnations
	Dim oViewRep As DesignViewRepresentation 'een view representation
	oViewReps = oAssyDefinition.RepresentationsManager.DesignViewRepresentations
	'lijst maken met alle view presentations van de varianten
	Dim ViewRepList As New ArrayList()
	For Each oViewRep In oViewReps
		ViewRepName = oViewRep.Name
		If ViewRepName.Contains("Materiaal = ")
			ViewRepList.Add(ViewRepName)
	Next
	Dim AmountViewReps As Integer = ViewRepList.Count
	ViewRepList.Sort 'op alfabetische volgorde
	i = 0 'teller voor view reps
	While (i < AmountViewReps)
		ViewRepName = ViewRepList(i)
		'Activate view rep
		Try
			oAssyDefinition.RepresentationsManager.DesignViewRepresentations.Item(ViewRepName).Activate
		Catch
			ModifiableBoolean = oAssyDoc.IsModifiable
			If ModifiableBoolean = False
				Try
					oAssyDoc = ThisApplication.Documents.Open(oAssyDoc.FullFileName, False)
				Catch
					MessageBox.Show("Probleem met activeren van:" & vbCrLf & ViewRepName & vbCrLf & vbCrLf & "CONTROLEER stuklijsten!", "ERROR: view representation activate - false", MessageBoxButtons.OK, MessageBoxIcon.Warning)
				End Try
			Else
				MessageBox.Show("Probleem met activeren van:" & vbCrLf & ViewRepName & vbCrLf & vbCrLf & "CONTROLEER stuklijsten!", "ERROR: view representation activate - true", MessageBoxButtons.OK, MessageBoxIcon.Warning)
		End Try
		BOMList.Clear()
		'Roep de function om BOM list te maken aan & voeg resultaten toe aan het totale overzicht
		EachOccurrence(oAssyDoc.ComponentDefinition.Occurrences)
		ProcessLists
		EndResultMessage = EndResultMessage & vbCrLf & vbCrLf & UCase(ViewRepName) & vbCrLf & CurrentVariantTable
		i = i + 1
		If i = 100 Then
			MessageBox.Show("View Reps loop blijft hangen. Mogelijk niet alle tabellen geplaatst.", "ERROR: View representation loop", MessageBoxButtons.OK, MessageBoxIcon.Error)
			Exit While
	End While
End Sub
Sub EachOccurrence(oOccs As ComponentOccurrences)
	'definities voor deze functie
	Dim OccurrenceFullName As String
	Dim OccurrencePartNumber As String
	Dim OccurrenceViewRep As String
	Dim OccurrenceAssembly As Boolean = False
	'Alle componenten langsgaan
	For Each occ In oOccs
		'Naam van occurrence in deze assembly
		OccurrenceFullName = occ.Name
		OccurrenceFullNameSplit = OccurrenceFullName.Split(":")
		'onzichtbare onderdelen & onderdelen waarvan om structure afwijkt eruit filteren, en naar lijst voor controle
		If occ.Visible = False
			Continue For
		Else
			Try
				If occ.Definition.BOMStructure = 51970 OrElse occ.Definition.BOMStructure = 51971 OrElse occ.Definition.BOMStructure = 51973 OrElse occ.Definition.BOMStructure = 51974
				Else
					Continue For
			Catch
				Continue For
			End Try
		'Bepaal view rep
		Try
			OccurrenceViewRep = occ.ActiveDesignViewRepresentation
		Catch
			OccurrenceViewRep = ""
		End Try
		'Bepaal partnumber
		Try
			OccurrencePartNumber = occ.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
		Catch
			OccurrencePartNumber = OccurrenceFullNameSplit(0)
		End Try
		If OccurrencePartNumber = ""
		PhantomAssemblyPart = False ' bijhouden of het een phantom assembly of onderdeel is
		If occ.Definition.BOMStructure = 51971
			'bepalen of het een assembly is
			Try
				If occ.DefinitionDocumentType = kAssemblyDocumentObject
					OccurrenceAssembly = True
				Else
					OccurrenceAssembly = False
			Catch
			End Try
			If OccurrenceAssembly = True
				'View representation activeren van de sub assembly
				If OccurrenceViewRep IsNot ""
					Try
						Dim oDoc As AssemblyDocument = occ.Definition.Document
						Dim occDef As ComponentDefinition = oDoc.ComponentDefinition
						occDef.RepresentationsManager.DesignViewRepresentations.Item(OccurrenceViewRep).Activate
						Call EachOccurrence(oDoc.ComponentDefinition.Occurrences)
					Catch
						Call EachOccurrence(occ.SubOccurrences)
					End Try
				Else
			PhantomAssemblyPart = True
		Else
			'Overige onderdelen in stuklijst plaatsen
			AddToList = OccurrencePartNumber & ":" & OccurrenceViewRep
			BOMList.Add(AddToList)
	Next
End Sub
Sub ProcessLists
'Strings leegmaken
CurrentVariantTable = ""
'Lists verwerken
	'Stuklijst sorteren en optellen
	Amount = BOMList.Count
	If Amount = 0
	Else
		BOMList.Sort
		TableRows = 0 'starten met 0 rijen
		i = 0 'Teller voor positie in de lijst
		j = 1 'Teller voor aantal exact zelfde in de lijst
		BOMListCurrent = "" 'Eerste is er nog geen current
		Dim RevisieCurrent As String = ""
		While (i < Amount)
			If BOMListCurrent = BOMList(i)
				'Als vorige gelijk is aan de huidige, dan aantal 1 omhoog
				j = j + 1
			Else If i = 0
				'Eerste waarde kan nog niet gekeken worden of hij gelijk is met de vorige
			Else
				'Vorige is niet gelijk, dus vorige word toegevoegd aan de lijst & de huidige word de current en begint op teller 1
				If CurrentVariantTable = ""
					 CurrentVariantTable = j & "x;" & BOMListCurrent
					 'eerste in de table toeveogen met het aantal
				Else
					CurrentVariantTable = CurrentVariantTable & vbCrLf & j & "x;" & BOMListCurrent
					'volgende in de table toevoegen achter de vorige met aantal
				j = 1 'teller voor aantal onderdelen gaat weer naar 1
				BOMListCurrent = BOMList(i) 'huidige word current
			If i = Amount - 1
				'Laatste van de rij moet ook toegevoegd worden, die word namelijk niet vergelijken met een volgende
				BOMListCurrentSplit = BOMListCurrent.Split(";")
					CurrentVariantTable = j & ";" & BOMListCurrent
				Else
				TableRows = TableRows + 1
			i = i + 1
			If i = 10000 Then
				MessageBox.Show("Vast gelopen in maken stuklijst. Niet complete stuklijst. (" & DocPartNumberChanged & ")", "ERROR: Stuklijst maken", MessageBoxButtons.OK, MessageBoxIcon.Error)
				Exit While
		End While
End Sub
daltonNYAW9
jaco011
The pop-ups are not the problem, the problem is that it wants to save. So each user has local copy's with 'newer' versions. And that it sometimes needs multiple runs due the blockage of inventor
daltonNYAW9
You could make the files not read-only
sFileName = ThisApplication.ActiveEditDocument.fullfilename
Dim oFile As System.IO.FileInfo
oFile = New System.IO.FileInfo(sFileName)
oFile.IsReadOnly = False
