Creating a directory
DeptaM
DeptaM
Good day everyone,
i need help with iLogic code. I have a rule that creates a Documentation directory and stores PDF and DWG from the drawing in it. I would need the created directory to be named Documentation \ Name of the parent directory.
I think it solves this line: oFolder = oPath & "\ Documentation (" & DateString & ")"
Thanks for the help
Martin Depta
JelteDeJong
You can create directories like this:
Dim oFolder = IO.Path.Combine(Path, "\ Documentation (" & DateString & ")")
Dim directoryInfo As IO.DirectoryInfo = IO.Directory.CreateDirectory(oFolder)
Jelte de Jong
Blog: hjalte.nl - github.com
