Creating 4 views
Creating 4 views
tomislav.peran
Message 1 of 15
Creating 4 views
tomislav.peran
I have tried to add views to my sheet but I can not seem to add projected views with the current code.
Should I just use "AddBaseView" everywhere instead of "AddProjectedView" because something is not working
with "AddProjectedView" option. Also it does not contain view orientation in itself so I am curious how program
knows how to choose the right side of the projected view.
This is idea:
And the code:
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(20, 20)
Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(20, 10)
Dim oPoint3 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(30, 10)
Dim oPoint4 As Point2d  = ThisApplication.TransientGeometry.CreatePoint2d(30,20)
Dim oPath As String = System.IO.Path.GetDirectoryName(oDrawingDoc.FullFileName)
Dim oAssyFullFileName As String = System.IO.Path.Combine(oPath, "iMachineIsland_top_assy.iam")
Dim oAssyDoc As AssemblyDocument = ThisApplication.Documents.Open(oAssyFullFileName, False)
Dim oBaseView As DrawingView
oBaseView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oPoint1, 1, kTopViewOrientation, kHiddenLineDrawingViewStyle)
Dim oView2 As DrawingView
oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2,kFromBaseDrawingViewStyle)
Dim oView3 As DrawingView
oView3 = oSheet.DrawingViews.AddProjectedView(oView2, oPoint3, kFromBaseDrawingViewStyle)
Dim oIsoView As DrawingView
Dim IsoView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oPoint4, 1, kIsoTopLeftViewOrientation, kHiddenLineDrawingViewStyle)
oAssyDoc.Close(True)
In case anyone knows what is wrong here with creating View 2 and View 3 please let me know.
Tom
Replies (14)
Message 2 of 15
SevInventor
Hello Tomislav,
instead of
try
oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
that works in one of my rules
Message 3 of 15
tomislav.peran
Hi SevInventor,
I still get the same errors:
De parameter is onjuist. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Error on line 26 in rule: Add view, in document: iMachineIsland_top_assy.idw
Klasse is niet geregistreerd
But thank you for your reply!
Tom
Message 4 of 15
SevInventor
try catch works here. I still don't know the reason for the error
	Try
	oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2,DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	Catch
	end try
	Try
	oView3 = oSheet.DrawingViews.AddProjectedView(oView2, oPoint3, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	Catch
	End Try
Message 5 of 15
tomislav.peran
I get no error indeed but also no views (except for the base and iso view where I use AddBaseView option).
If I figure it out where sits the mistake I will post it here.
Tom
Message 6 of 15
SevInventor
At this point it is not possible to place a paralell viev:
but for example here:
Dim oPoint3 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(20, 30)
Message 7 of 15
tomislav.peran
I have tried that as well but with no succes...
Message 8 of 15
SevInventor
this works for me:
'	Try
'	Catch
'	end try
'	Try
'	Catch
'	End Try
Message 9 of 15
tomislav.peran
Yes, it looks good. I have checked Inventor Help multiple times and the code for AddProjectView should look like you wrote it.
I will try again later. Maybe it will work then...
Message 10 of 15
SevInventor
Here is a problem:
should be
oIsoView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oPoint4, 1, kIsoTopLeftViewOrientation, kHiddenLineDrawingViewStyle)
a
Message 11 of 15
tomislav.peran
Hi Sev,
Yes, that is wrong but I corrected it already. Issue is in adding Projected views only. Those just can not be generated.
Maybe something is wrong with my files. Because code seems oke. I will try this code with other drawings to check if
it works.
But thanks a lot for helping out!
Tom
Message 12 of 15
WCrihfield
Hi @tomislav.peran.  Just dropping a link here to another similar post I recently worked on that you might benefit from.  The code in that other post was also creating drawings with 4 drawing views of part models, and includes code for figuring out scale and orientation of the models before placing the views.  Just in case that might help you out with your project.
Wesley Crihfield
(Not an Autodesk Employee)
Message 13 of 15
JelteDeJong
I did have a look at it. I did get an exception as well on the code. but I noticed that you are placing the views very close together. My theory is that they are too close. (also manually you are not able to put a projected view directly on top of a base view.) Try this code that I altered a bit.
Dim oBaseView As DrawingView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oPoint1, 0.1, ViewOrientationTypeEnum.kTopViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oPoint1.X, oPoint1.Y - oBaseView.Height)
Dim oView2 As DrawingView = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
Dim oPoint3 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oPoint2.X + oView2.Width, oPoint2.Y)
Dim oView3 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView2, oPoint3, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
Dim oPoint4 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oPoint3.X, oPoint3.Y + oView3.Height)
Dim oIsoView As DrawingView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oPoint4, 0.1, ViewOrientationTypeEnum.kIsoTopLeftViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Jelte de Jong
Blog: hjalte.nl - github.com
Message 14 of 15
tomislav.peran
Hi WCrihfield,
Thank you very much for your link! Looking forward reading it 🙂
Tom
Message 15 of 15
tomislav.peran
Hi Jelte,
It looks like your theory is correct!
In the original code ISO view was sucesfully created on top of the base view. But it has been seen by Inventor as an other base view not as projected view. It is logical to think that in that case distance does not matter.
Thank you very much for helping, veel bedankt 🙂
Tom
