Create Work Axis for Punch Feature items
checkcheck_master
checkcheck_master
Hi there,
To constrain things to a Puch Feature we've add a Work Axis to the punches.
I would like to automate that process.
With:
For Each oSketch In oDoc.ComponentDefinition.Sketches
  Dim oPoint As Inventor.SketchPoint
  For Each oPoint In oSketch.SketchPoints
    oDef.WorkAxes.AddByNormalToSurface(oSketch.PlanarEntity, oPoint)
  Next
Next
For each and every point an Axis is created, fillets etc. which is a little too much.
How can I filter/get only the Points who belong to a Punch Feature?
Greetings!
Ralf_Krieg
Hello
Try this:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
Dim oPunchToolFeature As PunchToolFeature
For Each oPunchToolFeature In oDoc.ComponentDefinition.Features.PunchToolFeatures
    For Each oPoint In oPunchToolFeature.PunchCenterPoints
        oSketch = oPoint.Parent
    Next
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
checkcheck_master
Wonderful Krieg, thanks a lot!
I'm trying to study the API Object Model and searching the API help to get my solutions.
You've got any tips/links/documents learning this?
How to add only Axis that not already exist?
Can I iterate the already existing Axes and check for a reference with a Punch feature?
Greetings!
Ralf_Krieg
Hello
This can be done by comparing the definition point of the work axis and the sketch point. If the current sketch point is the same as one definition point of an existing work axis, the script would skip creating a new one.
Private Sub Main()
			If PointUsed(oDef,oPoint) = False Then
	    Next
	Next
End Sub
Private Function PointUsed(ByVal oDef As PartComponentDefinition, ByVal oPoint As Inventor.SketchPoint) As Boolean
	Dim oWorkAxis As Inventor.WorkAxis
	Dim oWorkAxisDef As NormalToSurfaceWorkAxisDef
	For Each oWorkAxis In oDef.WorkAxes
		If oWorkAxis.DefinitionType = WorkAxisDefinitionEnum.kNormalToSurfaceWorkAxis Then
			oWorkAxisDef = oWorkAxis.Definition
			If oWorkAxisDef.Point Is oPoint Then
				Return True
	Next
	Return False
End Function
R. Krieg
RKW Solutions
checkcheck_master
Thanks again Krieg!
I'm so free to ask you another question about an earlier topic we discussed, the renaming of the sketches.
Basically it works until a sketch number appears that already exist, despite this not apparent from the recursive search of all sketches based on the browser tree. In my head I can reason the solution, but converting it into the correct code is still a thing. I understand that I have to take another variable that has to be incremented every time the renaming was successful and I need a boolean that indicates whether or not the rename was successful. Specific this I struggle with.
Please see the code, 1ste the part I struggle with, starting by 'Rename temp', 2nd some corresponding variables and the cursive function and 3th the complete code.
Thanks in advance.
Greetings!
' Rename Sketches
' Iterate BrowserNodes and collect all Sketches
	Dim oPane As BrowserPane
    ' Get the BrowserPane that support the search box.
    If oPartDoc.DocumentType = kPartDocumentObject Then
         oPane = oPartDoc.BrowserPanes("PmDefault")
    ElseIf oPartDoc.DocumentType = kAssemblyDocumentObject Then
         oPane = oPartDoc.BrowserPanes("AmBrowserArrangement")
    ElseIf oPartDoc.DocumentType = kDrawingDocumentObject Then
         oPane = oPartDoc.BrowserPanes("DlHierarchy")
    ElseIf oPartDoc.DocumentType = kPresentationDocumentObject Then
         oPane = oPartDoc.BrowserPanes("DxHierarchy")
    Dim items As String
    items = GetBrowserNodes(oPane.TopNode.BrowserNodes)
	' Reset PassedOrigin
	PassedOrigin = False
'	MessageBox.Show(items)
'	oWrite.WriteLine("items as String:")
'	oWrite.WriteLine(items)
'	oWrite.WriteLine("")
'For Each element In ListWithSketches
'	oWrite.WriteLine(element)
'Next
		'ListWithSketches.sort
' Overview
For i = 0 To ListWithSketches.count - 1
	oWrite.WriteLine(i+1 & ": " & ListWithSketches(i) & " (ListWithSketches)")
Next
		For i = 1 To oPartDoc.ComponentDefinition.Sketches.Count
		    oWrite.WriteLine(i & ": " & oPartDoc.ComponentDefinition.Sketches(i).Name & " (oPartDoc.ComponentDefinition.Sketches)")
		Next
		' Sketch nummer uit ListWithSketches(i) obv inhoud
		    oWrite.WriteLine(Replace(ListWithSketches(i),"Sketch",""))
		Next
		' Rename temp
		oWrite.WriteLine("Rename: ")
		' Doorloop alle gevonden Sketches
		Dim j As Integer
		Dim l As Integer
			oWrite.WriteLine("ListWithSketches " & i+1 & ": " & ListWithSketches(i))
			'Zoek de gevonden Sketch in de 'Inventor volgorde lijst' en hernoem deze plaats vzv Temp
			For j = 1 To oPartDoc.ComponentDefinition.Sketches.Count
		    	'oWrite.WriteLine(PartDoc.ComponentDefinition.Sketches(i).Name & " (oPartDoc.ComponentDefinition.Sketches)")
				If oPartDoc.ComponentDefinition.Sketches(j).Name = ListWithSketches(i) Then
					'Dim Bool As Boolean
					'If Not oPartDoc.ComponentDefinition.Sketches(j).Name = "Sketch" & i + 1 & " Temp" Then Bool =  False
					'oWrite.WriteLine("Rename Sketch result: " & Bool)
					On Error Resume Next
					If bool(oPartDoc.ComponentDefinition.Sketches(j).Name = "Sketch" & i + 1 & " Temp") Then
				'oWrite.WriteLine(i & ": " & oPartDoc.ComponentDefinition.Sketches(i).Name & " (oPartDoc.ComponentDefinition.Sketches)")
			Next
		Next
		' Rename final
			'If oPartDoc.ComponentDefinition.Sketches(j).Name = ListWithSketches(i) Then
				oPartDoc.ComponentDefinition.Sketches(j).Name = Replace(oPartDoc.ComponentDefinition.Sketches(j).Name," Temp","")
			'End If
		Next
' List to collect all Sketches from BrowserNodes
Public ListWithSketches As New List(Of String)
'Public ListWithSketches As New SortedList(Of String, Integer)
'Public C As Integer = 1
' Om de Sketches 'zuiver' te krijgen gaan we ze pas verzamelen nadat we de 'Origin' zijn gepasseerd
' Anders krijgen we ook de Sketches onder 'Solid' waarbij de volgorde niet overeen komt wanneer er oa Shared Sketches voorkomen
Public PassedOrigin As Boolean
Function GetBrowserNodes(nodes As BrowserNodesEnumerator) As String
	Dim node As BrowserNode
    For Each node In nodes
        If node.BrowserNodeDefinition.Label.ToString Like "*Origin*" Then PassedOrigin = True
		If node.BrowserNodeDefinition.Label.ToString Like "*Sketch*" And PassedOrigin = True Then
		'If IsNumeric(Right(node.BrowserNodeDefinition.Label.ToString,1)) Then
		'If node.Selected Then
            If ListWithSketches.Contains(node.BrowserNodeDefinition.Label.ToString) = False Then
			'If ListWithSketches.Containsvalue(node.BrowserNodeDefinition.Label.ToString) = False Then
				ListWithSketches.Add(node.BrowserNodeDefinition.Label.ToString)
				'ListWithSketches.Add(C, node.BrowserNodeDefinition.Label.ToString)
				'C= C + 1
		'End If
		'End If
		' For Debugging, check items as String in Sub Main
		GetBrowserNodes = GetBrowserNodes + vbCrLf + node.BrowserNodeDefinition.Label.ToString
        GetBrowserNodes = GetBrowserNodes + GetBrowserNodes(node.BrowserNodes)
    Next
	Return ListWithSketches.ToString
End Function
Sub Main()
' Write to textfile
Dim strDateAndTime As String
strDateAndTime = DateTime.Now.ToString(("yyyy-MM-dd HHmmss"))
Dim LogFileName As String
LogFileName = "C:\temp\iLogic_Log_" & strDateAndTime & ".txt"
oWrite = System.IO.File.CreateText(LogFileName)
'oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
' Calculate elapsed time
Dim oWatch As New Stopwatch
oWatch.Start
' Features
Dim iAliasFreeform As Integer
Dim iBend As Integer
Dim iBoss As Integer
Dim iBoundaryPatch As Integer
Dim iChamfer As Integer
Dim iCircularpattern As Integer
Dim iClient As Integer
Dim iCoil As Integer
Dim iCombine As Integer
Dim iCoreCavity As Integer
Dim iCornerChamferFeatureObject As Integer
Dim iCornerRoundFeatureObject As Integer
Dim iContourFlangeFeatureObject As Integer
Dim iCutFeatureObject As Integer
Dim iDecal As Integer
Dim iDeleteFace As Integer
Dim iDirectEdit As Integer
Dim iEmboss As Integer
Dim iExtend As Integer
Dim iExtrude As Integer
Dim iFaceDraft As Integer
Dim iFace As Integer
Dim iFaceOffset As Integer
Dim iFillet As Integer
Dim iFlangeFeatureObject As Integer
Dim iFreeform As Integer
Dim iGrill As Integer
Dim iHole As Integer
Dim iKnit As Integer
Dim iLip As Integer
Dim iLoft As Integer
Dim iMidsurface As Integer
Dim iMirror As Integer
Dim iMoveFace As Integer
Dim iMove As Integer
Dim iNonParametricBaseFeatureObject As Integer
'NonParametricBaseFeature
'NonParametricBaseFeatures
Dim kPunchToolFeatureObject As Integer
Dim iRectangularPattern As Integer
'Reference
Dim iReplaceFace As Integer
Dim iRest As Integer
Dim iRevolve As Integer
Dim iReferenceFeatureObject As Integer
Dim iRib As Integer
Dim iRuledSurface As Integer
Dim iRuleFillet As Integer
Dim iSculpt As Integer
Dim iShell As Integer
Dim iSketchDrivenPattern As Integer
Dim iSnapFit As Integer
Dim iSplit As Integer
Dim kSurfaceBodyObject As Integer
Dim iSweep As Integer
Dim iThicken As Integer
Dim iThread As Integer
Dim iTrim As Integer
Dim iUnwrap As Integer
Dim i As Integer
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oFeatures As PartFeatures = oPartDoc.ComponentDefinition.Features
Dim oDef As PartComponentDefinition = oPartDoc.ComponentDefinition
' Rebuild All
ThisDoc.Document.Rebuild()
'' For Debugging
'oWrite.WriteLine("")
'For Each oFeature In oFeatures
' 	oWrite.WriteLine("Before actions: " & oFeature.name)
'Next
' Undo Wrapper
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oPartDoc, "Do your thing...")
' Rename Solid Bodies
Dim iSolidCount As Integer
Dim oSolid As SurfaceBody
For Each oSolid In oDef.SurfaceBodies
	iSolidCount = iSolidCount + 1
	oSolid.Name = "Solid" & iSolidCount.ToString & " " & strDateAndTime
Next
	iSolidsCount = 0
		iSolidsCount = iSolidCount + 1
	Next
' Work Features
Dim iWorkPlane As Integer
Dim iWorkPoint As Integer
Dim iWorkAxis As Integer
Dim iWorkSurface As Integer
' Rename Work Features:
' Rename Work Planes
For Each oWorkPlane In oDef.WorkPlanes
	If 	oWorkPlane.Name <> "Start plane" And oWorkPlane.Name <> "End plane" Then
		If oWorkPlane.IsCoordinateSystemElement = False  Then
			iWorkPlane = iWorkPlane + 1
			oWorkPlane.Name = "Work Plane" & iWorkPlane.ToString & " " & strDateAndTime
Next
		iWorkPlane = 0
		Next
' Rename Work Points
For Each oWorkPoint In oDef.WorkPoints
	If oWorkPoint.IsCoordinateSystemElement = False  Then
		iWorkPoint = iWorkPoint + 1
		oWorkPoint.Name = "Work Point" & iWorkPoint.ToString & " " & strDateAndTime
Next
	iWorkPoint = 0
	Next
' Rename Work Axis
	If oWorkAxis.IsCoordinateSystemElement = False  Then
		iWorkAxis = iWorkAxis + 1
		oWorkAxis.Name = "Work Axis" & iWorkAxis.ToString & " " & strDateAndTime
Next
	iWorkAxis = 0
	Next
' Rename Work Surface
For Each oWorkSurface In oDef.WorkSurfaces
	iWorkSurface = iWorkSurface + 1
	oWorkSurface.Name = "Work Surface" & iWorkSurface.ToString & " " & strDateAndTime
Next
	iWorkSurface = 0
	Next
'Rename Features
For i = 1 To oFeatures.Count
	If oFeatures(i).Name <> "Body" And _
	   oFeatures(i).Name <> "Driven Length" And _
	   oFeatures(i).Type <> ObjectTypeEnum.kReferenceFeatureObject Then
    		oFeatures(i).Name = i & " " & strDateAndTime
	end if
Next
'MessageBox.Show("Wait...")
    Select Case oFeatures(i).Type
        Case ObjectTypeEnum.kAliasFreeformFeatureObject:
            iAliasFreeform = iAliasFreeform + 1
            oFeatures(i).Name = "Alias Freeform" & CStr(iAliasFreeform)
        Case ObjectTypeEnum.kBendFeatureObject:
            iBend = iBend + 1
            oFeatures(i).Name = "Bend" & CStr(iBend)
        Case ObjectTypeEnum.kBossFeatureObject:
            iBoss = iBoss + 1
            oFeatures(i).Name = "Boss" & CStr(iBoss)
        Case ObjectTypeEnum.kBoundaryPatchFeatureObject:
            iBoundaryPatch = iBoundaryPatch + 1
            oFeatures(i).Name = "Boundary Patch" & CStr(iBoundaryPatch)
        Case ObjectTypeEnum.kChamferFeatureObject:
            iChamfer = iChamfer + 1
            oFeatures(i).Name = "Chamfer" & CStr(iChamfer)
        Case ObjectTypeEnum.kCircularPatternFeatureObject:
            iCircularpattern = iCircularpattern + 1
            oFeatures(i).Name = "Circular Pattern" & CStr(iCircularpattern)
        Case ObjectTypeEnum.kClientFeatureObject:
            If oFeatures(i).Name <> "Driven Length"
				iClient = iClient + 1
            	oFeatures(i).Name = "Client" & CStr(iClient)
		Case ObjectTypeEnum.kCoilFeatureObject :
            iCoil = iCoil + 1
            oFeatures(i).Name = "Coil" & CStr(iCoil)
        Case ObjectTypeEnum.kCombineFeatureObject:
            iCombine = iCombine + 1
            oFeatures(i).Name = "Combine" & CStr(iCombine)
        Case ObjectTypeEnum.kCoreCavityFeatureObject:
            iCoreCavity = iCoreCavity + 1
            oFeatures(i).Name = "Core Cavity" & CStr(iCoreCavity)
		Case ObjectTypeEnum.kCornerChamferFeatureObject:
            iCornerChamferFeatureObject = iCornerChamferFeatureObject + 1
            oFeatures(i).Name = "Corner Chamfer" & CStr(iCornerChamferFeatureObject)
		Case ObjectTypeEnum.kCornerRoundFeatureObject:
            iCornerRound = iCornerRound + 1
            oFeatures(i).Name = "Corner Round" & CStr(iCornerRound)
		Case ObjectTypeEnum.kContourFlangeFeatureObject:
            iContourFlangeFeatureObject = iContourFlangeFeatureObject + 1
            oFeatures(i).Name = "Contour Flange" & CStr(iContourFlangeFeatureObject)
		Case ObjectTypeEnum.kCutFeatureObject:
            iCut = iCut + 1
            oFeatures(i).Name = "Cut" & CStr(iCut)
		Case ObjectTypeEnum.kDecalFeatureObject :
            iDecal = iDecal + 1
            oFeatures(i).Name = "Decal" & CStr(iDecal)
        Case ObjectTypeEnum.kDeleteFaceFeatureObject:
            iDeleteFace = iDeleteFace + 1
            oFeatures(i).Name = "Delete Face" & CStr(iDeleteFace)
        Case ObjectTypeEnum.kDirectEditFeatureObject:
            iDirectEdit = iDirectEdit + 1
            oFeatures(i).Name = "Direct Edit" & CStr(iDirectEdit)
        Case ObjectTypeEnum.kEmbossFeatureObject:
            iEmboss = iEmboss + 1
            oFeatures(i).Name = "Emboss" & CStr(iEmboss)
        Case ObjectTypeEnum.kExtendFeatureObject:
            iExtend = iExtend + 1
            oFeatures(i).Name = "Extend" & CStr(iExtend)
		Case ObjectTypeEnum.kExtrudeFeatureObject :
			'messagebox.Show(oFeatures(i).Name)
            If oFeatures(i).Name <> "Body" Then
				iExtrude = iExtrude + 1
				''MessageBox.Show(iExtrude & " - i =" & i & " - CStr: " & CStr(iExtrude))
				oFeatures(i).Name = "Extrusion" & CStr(iExtrude)
		Case ObjectTypeEnum.kFaceDraftFeatureObject :
            iFaceDraft = iFaceDraft + 1
            oFeatures(i).Name = "Face Draft" & CStr(iFaceDraft)
		Case ObjectTypeEnum.kFaceFeatureObject:
            iFace = iFace + 1
            oFeatures(i).Name = "Face" & CStr(iFace)
		Case ObjectTypeEnum.kFaceOffsetFeatureObject :
            iFaceOffset = iFaceOffset + 1
            oFeatures(i).Name = "Face Offset" & CStr(iFaceOffset)
        Case ObjectTypeEnum.kFilletFeatureObject:
            iFillet = iFillet + 1
            oFeatures(i).Name = "Fillet" & CStr(iFillet)
		Case ObjectTypeEnum.kFlangeFeatureObject:
            iFlangeFeatureObject = iFlangeFeatureObject + 1
            oFeatures(i).Name = "Flange" & CStr(iFlangeFeatureObject)
		Case ObjectTypeEnum.kFreeformFeatureObject :
            iFreeform = iFreeform + 1
            oFeatures(i).Name = "Freeform" & CStr(iFreeform)
        Case ObjectTypeEnum.kGrillFeatureObject:
            iGrill = iGrill + 1
            oFeatures(i).Name = "Grill" & CStr(iGrill)
        Case ObjectTypeEnum.kHoleFeatureObject:
            iHole = iHole + 1
            oFeatures(i).Name = "Hole" & CStr(iHole)
        Case ObjectTypeEnum.kKnitFeatureObject:
            iKnit = iKnit + 1
            oFeatures(i).Name = "Knit" & CStr(iKnit)
        Case ObjectTypeEnum.kLipFeatureObject:
            iLip = iLip + 1
            oFeatures(i).Name = "Lip" & CStr(iLip)
        Case ObjectTypeEnum.kLoftFeatureObject:
            iLoft = iLoft + 1
            oFeatures(i).Name = "Loft" & CStr(iLoft)
        Case ObjectTypeEnum.kMidSurfaceFeatureObject:
            iMidsurface = iMidsurface + 1
            oFeatures(i).Name = "Midsurface" & CStr(iMidsurface)
        Case ObjectTypeEnum.kMirrorFeatureObject:
            iMirror = iMirror + 1
            oFeatures(i).Name = "Mirror" & CStr(iMirror)
        Case ObjectTypeEnum.kMoveFaceFeatureObject:
            iMoveFace = iMoveFace + 1
            oFeatures(i).Name = "MoveFace" & CStr(iMoveFace)
		Case ObjectTypeEnum.kNonParametricBaseFeatureObject:
            iNonParametricBaseFeatureObject = iNonParametricBaseFeatureObject + 1
            oFeatures(i).Name = "Solid Body" & CStr(iNonParametricBaseFeatureObject)
		Case ObjectTypeEnum.kMoveFeatureObject :
            iMove = iMove + 1
            oFeatures(i).Name = "Move" & CStr(iMove)
		Case ObjectTypeEnum.kPunchToolFeatureObject:
            iPunchToolFeature = iPunchToolFeature + 1
            oFeatures(i).Name = "Punch Tool Feature" & CStr(iPunchToolFeature)
        Case ObjectTypeEnum.kRectangularPatternFeatureObject:
            iRectangularPattern = iRectangularPattern + 1
            oFeatures(i).Name = "Rectangular Pattern" & CStr(iRectangularPattern)
		Case ObjectTypeEnum.kReferenceFeatureObject:
            ' Do nothing waarschijnlijk een mirrorpart
			'iReferenceFeatureObject = iReferenceFeatureObject + 1
            'oFeatures(i).Name = "Rectangular Pattern" & CStr(iReferenceFeatureObject)
        Case ObjectTypeEnum.kReplaceFaceFeatureObject:
            iReplaceFace = iReplaceFace + 1
            oFeatures(i).Name = "ReplaceFace" & CStr(iReplaceFace)
        Case ObjectTypeEnum.kRestFeatureObject:
            iRest = iRest + 1
            oFeatures(i).Name = "Rest" & CStr(iRest)
        Case ObjectTypeEnum.kRevolveFeatureObject:
            iRevolve = iRevolve + 1
            oFeatures(i).Name = "Revolve" & CStr(iRevolve)
        Case ObjectTypeEnum.kRibFeatureObject:
            iRib = iRib + 1
            oFeatures(i).Name = "Rib" & CStr(iRib)
        Case ObjectTypeEnum.kRuledSurfaceFeatureObject:
            iRuledSurface = iRuledSurface + 1
            oFeatures(i).Name = "Ruled Surface" & CStr(iRuledSurface)
        Case ObjectTypeEnum.kRuleFilletFeatureObject:
            iRuleFillet = iRuleFillet + 1
            oFeatures(i).Name = "Rule Fillet" & CStr(iRuleFillet)
        Case ObjectTypeEnum.kSculptFeatureObject:
            iSculpt = iSculpt + 1
            oFeatures(i).Name = "Sculpt" & CStr(iSculpt)
        Case ObjectTypeEnum.kShellFeatureObject:
            iShell = iShell + 1
            oFeatures(i).Name = "Shell" & CStr(iShell)
        Case ObjectTypeEnum.kSketchDrivenPatternFeatureObject:
            iSketchDrivenPattern = iSketchDrivenPattern + 1
            oFeatures(i).Name = "Sketch Driven Pattern" & CStr(iSketchDrivenPattern)
        Case ObjectTypeEnum.kSnapFitFeatureObject:
            iSnapFit = iSnapFit + 1
            oFeatures(i).Name = "SnapFit" & CStr(iSnapFit)
        Case ObjectTypeEnum.kSplitFeatureObject:
            iSplit = iSplit + 1
            oFeatures(i).Name = "Split" & CStr(iSplit)
		Case ObjectTypeEnum.kSurfaceBodyObject:
            ikSurfaceBodyObject = ikSurfaceBodyObject + 1
            oFeatures(i).Name = "Solid" & CStr(ikSurfaceBodyObject)
        Case ObjectTypeEnum.kSweepFeatureObject:
            iSweep = iSweep + 1
            oFeatures(i).Name = "Sweep" & CStr(iSweep)
        Case ObjectTypeEnum.kThickenFeatureObject:
            iThicken = iThicken + 1
            oFeatures(i).Name = "Thicken" & CStr(iThicken)
        Case ObjectTypeEnum.kThreadFeatureObject:
            iThread = iThread + 1
            oFeatures(i).Name = "Thread" & CStr(iThread)
        Case ObjectTypeEnum.kTrimFeatureObject:
            iTrim = iTrim + 1
            oFeatures(i).Name = "Trim" & CStr(iTrim)
' Not for IV2019
'        Case ObjectTypeEnum.kUnwrapFeatureObject:
'            iUnwrap = iUnwrap + 1
'            oFeatures(i).Name = "Unwrap" & CStr(iUnwrap)
        Case Else:
            MsgBox ("Unknown feature detected: " & CStr(oFeatures(i).Type))
    End Select
Next
' Rename Sketches
    Dim items As String
'Next
' Overview
Next
		Next
		Next
		' Rename temp
		Dim j As Integer
		Dim l As Integer
			Next
		Next
		' Rename final
			'End If
		Next
'		For i = 1 To oPartDoc.ComponentDefinition.Sketches.Count
'		    oPartDoc.ComponentDefinition.Sketches(i).Name = "Sketch" & Replace(ListWithSketches(i-1),"Sketch","") & " Temp"
'		Next
'		' Rename
'		    oPartDoc.ComponentDefinition.Sketches(i).Name = Replace(oPartDoc.ComponentDefinition.Sketches(i).Name, "Temp", "")
'			oPartDoc.ComponentDefinition.Sketches(i).Name = Replace(oPartDoc.ComponentDefinition.Sketches(i).Name," ","")
'		Next
		' Result
		Next
		' Refill List
		ListWithSketches.clear
		Dim items2 As String
		items2 = GetBrowserNodes(oPane.TopNode.BrowserNodes)
		' Overview
		Next
'		MessageBox.Show(items2)
'Dim oSketch As Sketch
'For i = 1 To oPartDoc.ComponentDefinition.Sketches.Count
'    oWrite.WriteLine(oPartDoc.ComponentDefinition.Sketches(i).Name & " - " & ListWithSketches(i-1))
'Next
'    oPartDoc.ComponentDefinition.Sketches(i).Name = ListWithSketches(i-1) & strDateAndTime
'Next
'Next
'oWrite.WriteLine("----------------------------------------------------------------------------------------------------")
'Next
' Undo Wrapper
trans.End()
'		' Test
'		For i = 1 To oPartDoc.ComponentDefinition.Features.ReferenceFeatures.Count
'		    oWrite.WriteLine(oPartDoc.ComponentDefinition.Features.ReferenceFeatures(i).Name)
'		Next
'		For Each oSolid In oDef.SurfaceBodies
'			For Each oSolid1 In oSolid.Faces
'				For Each osolid3 In oSolid1.ed..iSolidCount = iSolidCount + 1
'				Next
'			Next
'		Next
'MsgBox("Done",,"iLogic")
' Rebuild All
'' For Debugging
' 	oWrite.WriteLine("After actions: " & oFeature.name)
'Next
'Calculate elapsed time.
oWatch.Stop()
oWrite.WriteLine(vbNewLine & "Done!" & vbNewLine & ("Elapsed Time: " & oWatch.ElapsedMilliseconds.ToString & " Milliseconds"))
'MsgBox         (vbNewLine & "Done!" & vbNewLine & ("Elapsed Time: " & oWatch.ElapsedMilliseconds.ToString & " Milliseconds"))
oWrite.Close()
'Dim p As System.Diagnostics.Process = Process.Start(LogFileName)
ThisDoc.Launch(LogFileName)
'ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
'Set focus back the Inventor application
Dim App As Process() = Process.GetProcessesByName("Inventor")
If App.Length > 0 Then
	AppActivate(App(0).Id)
End Sub
				'C= C + 1
		'End If
		'End If
    Next
End Function
Ralf_Krieg
Hello
Take a look at my new idea in this thread . Maybe this is a solution even for this problem.
R. Krieg
RKW Solutions
checkcheck_master
Hello Krieg,
I posted a message with a question in https://forums.autodesk.com/t5/inventor-customization/ilogic-get-all-underlying-feature-items/td-p/1....
If you have the opportunity to answer, please.
