Create UCSs from List with iLogic
Curtis_Waguespack
Consultant Consultant
Curtis_Waguespack
I thought I would share this example here in case it is of help to someone in the future.
This creates UCSs based on a list setting the XYZ locations and rotations. If the named UCS exists already it simply updates it.
A big thank you to @JhoelForshav for his example from this link to create the matrix
https://forums.autodesk.com/t5/inventor-programming-ilogic/ilogic-place-a-part-and-define-rotation/m...
Curtis_Waguespack
Sub Main
	Dim UCSList As New ArrayList
	'UCS Name | X location| Y location| Z location| X rotation | Y rotation | Z rotation
	UCSList.Add("UCS01|0|0|12|010|0|0")
	UCSList.Add("UCS02|0|0|24|045|0|0")
	UCSList.Add("UCS03|0|0|36|135|0|0")
	'send striing to sub routine
	For Each ListString In UCSList : ParseStrings(ListString) : Next
	iLogicVb.UpdateWhenDone = True
End Sub
Sub ParseStrings(ListString As String)
	' Get the active document
	Dim oDoc As Document = ThisDoc.Document
	Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
	'split each string using the | as the split character
	StringArray = Split(ListString, "|")
	ArrayCount = UBound(StringArray)
	If ArrayCount < 6 Then
		MsgBox(ListString & vbLf & "Only " & ArrayCount & " ' | ' seperator chrs in string" & vbLf & "Expected 6", , "ilogic")
		Exit Sub
	'set up conversion factors
	Dim DocumentUnitsOfMeasure As UnitsOfMeasure = oDoc.UnitsOfMeasure
	Cnvt_in_to_cm = DocumentUnitsOfMeasure.ConvertUnits(1, UnitsTypeEnum.kInchLengthUnits, UnitsTypeEnum.kCentimeterLengthUnits)
	UCSName = StringArray(0) 'first item in array
	UCS_LocationX = StringArray(1) * Cnvt_in_to_cm
	UCS_LocationY = StringArray(2) * Cnvt_in_to_cm
	UCS_LocationZ = StringArray(3) * Cnvt_in_to_cm
	UCS_RotationX = StringArray(4)
	UCS_RotationY = StringArray(5)
	UCS_RotationZ = StringArray(6)
	' Get the UCS collection
	Dim oUCSs As UserCoordinateSystems = oCompDef.UserCoordinateSystems
	Dim oUCS As UserCoordinateSystem = Nothing
	'check for existing	UCS
	For Each oExistingUCS In oUCSs
		If oExistingUCS.name = UCSName Then
			oUCS = oExistingUCS
			Exit For
	Next
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oUCSDef As UserCoordinateSystemDefinition = oUCSs.CreateDefinition()
	Dim oMatrix As Inventor.Matrix = oTG.CreateMatrix()
	'add new UCS if needed
	If oUCS Is Nothing Then oUCS = oUCSs.Add(oUCSDef)
	'create posistion and rotation matrix
	oMatrix = CreateMatrixRotate(UCS_LocationX, UCS_LocationY, UCS_LocationZ, UCS_RotationX, UCS_RotationY, UCS_RotationZ, "X,Y,Z")
	oUCS.Transformation = oMatrix
	'set name
	oUCS.Name = UCSName
	oUCS.Visible = True
End Sub
'JhoelForshav's matrix function and subs
'https://forums.autodesk.com/t5/inventor-programming-ilogic/ilogic-place-a-part-and-define-rotation/m-p/8983364/highlight/true#M100656
'[ expand to see code
Function CreateMatrixRotate(X As Double, Y As Double, Z As Double, _
	XAngleDeg As Double, YAngleDeg As Double, ZAngleDeg As Double, oRotateOrder As String) As Matrix
	Dim XAngle As Double = XAngleDeg * (Math.PI / 180)
	Dim YAngle As Double = YAngleDeg * (Math.PI / 180)
	Dim ZAngle As Double = ZAngleDeg * (Math.PI / 180)
	Dim oTg As Inventor.TransientGeometry = ThisApplication.TransientGeometry
	Dim oMatrix As Matrix = oTg.CreateMatrix
	'ROTATE MATRIX
	Dim oFirstAxis As String = oRotateOrder.Split(",")(0)
	Dim oSecondAxis As String = oRotateOrder.Split(",")(1)
	Dim oThirdAxis As String = oRotateOrder.Split(",")(2)
	If oFirstAxis = "X"
		RotateAroundX(oMatrix, XAngle)
	ElseIf oFirstAxis = "Y"
		RotateAroundY(oMatrix, YAngle)
	ElseIf oFirstAxis = "Z"
		RotateAroundZ(oMatrix, ZAngle)
	If oSecondAxis = "X"
	ElseIf oSecondAxis = "Y"
	ElseIf oSecondAxis = "Z"
	If oThirdAxis = "X"
	ElseIf oThirdAxis = "Y"
	ElseIf oThirdAxis = "Z"
	'Translate Matrix
	Dim oTranslateVector As Vector = oTg.CreateVector(X / 10, Y / 10, Z / 10)
	oMatrix.SetTranslation(oTranslateVector, False)
	Return oMatrix
End Function
Sub RotateAroundX(oMatrix As Matrix, rotationAngle As Double)
	Dim oRotateMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
	oRotateMatrix.Cell(1, 1) = 1
	oRotateMatrix.Cell(1, 2) = 0
	oRotateMatrix.Cell(1, 3) = 0
	oRotateMatrix.Cell(2, 1) = 0
	oRotateMatrix.Cell(2, 2) = Math.Cos(rotationAngle)
	oRotateMatrix.Cell(2, 3) = -Math.Sin(rotationAngle)
	oRotateMatrix.Cell(3, 1) = 0
	oRotateMatrix.Cell(3, 2) = Math.Sin(rotationAngle)
	oRotateMatrix.Cell(3, 3) = Math.Cos(rotationAngle)
	oMatrix.TransformBy(oRotateMatrix)
End Sub
Sub RotateAroundY(oMatrix As Matrix, rotationAngle As Double)
	oRotateMatrix.Cell(1, 1) = Math.Cos(rotationAngle)
	oRotateMatrix.Cell(1, 3) = Math.Sin(rotationAngle)
	oRotateMatrix.Cell(2, 2) = 1
	oRotateMatrix.Cell(2, 3) = 0
	oRotateMatrix.Cell(3, 1) = -Math.Sin(rotationAngle)
	oRotateMatrix.Cell(3, 2) = 0
End Sub
Sub RotateAroundZ(oMatrix As Inventor.Matrix, rotationAngle As Double)
	oRotateMatrix.Cell(1, 2) = -Math.Sin(rotationAngle)
	oRotateMatrix.Cell(2, 1) = Math.Sin(rotationAngle)
	oRotateMatrix.Cell(3, 3) = 1
End Sub
WCrihfield
Hi @Curtis_Waguespack.  Nice code example.  I haven't tried it yet, but while quickly reading down over the code in your post, I saw something that I thought I should point-out, just in case it may be a typo or copy/paste mistake type situation.  In the image below of a portion of the code within the CreateParams method, I have something circled.  Seems like that last 5 should be a 6, but I could be wrong.
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
@WCrihfield, nice catch!
You're exactly right.
I was reusing some code as the basis for this.
I updated the previous post to fix the string array. And changed also changed the name of the sub from CreateParms to ParseStrings, which makes a bit more sense.
Thanks!
