Create Text/sketch on a face in a assembly with iLogic
nickolas_jaderas
nickolas_jaderas
In a assembly (or part), I want to select a face, on this face I want the Partnumber as a sketh text, (with a big font)
Is there a simple solution?
I haven't found any examples of this, not even how to create a sketch simply by selecting a face with iLogic.
/Nickolas
xiaodong_liang
Autodesk Support
Autodesk Support
nickolas_jaderas
Awsome!
Changed it somehow to take a custom property and let the user select the face.
Is it possible to change the font size? since the part is a few meters in size, I have to use fontsize 300.
Also if its possible, add the text as a text-box, that way no text-point is visible.
SyntaxEditor Code Snippet
oAssDoc = ThisApplication.ActiveDocument
oAssDef = oAssDoc.ComponentDefinition
itemNo = iProperties.Value("Custom", "ItemNo")
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities,"Select the face")
    'make sure it is a planar face
    If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
        oPlanarSurface = oFace.Geometry
            'add a sketch
        oSketch = oAssDef.Sketches.Add(oFace)
        'trying to choose an appropriate point
        'assume this planar face has one edge loop only
        oEdgeLoop = oFace.EdgeLoops(1)
        oMinPt = oEdgeLoop.RangeBox.MinPoint
        oMaxPt = oEdgeLoop.RangeBox.MaxPoint
        CenterPt = ThisApplication.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
        'get one point on the face and transform to the point2d on the sketch
        'Set oTextPt = oSketch.ModelToSketchSpace(oPlanarSurface.RootPoint)
        oTextPt = oSketch.ModelToSketchSpace(CenterPt)
            'add the textbox
        'oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, "MY TEST")
        oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, itemNo)
    Else
        MsgBox( "please select a planar face!")
xiaodong_liang
Autodesk Support
Autodesk Support
the easiest way is to specify the font size like below:
'double size
oSketchText.Style.FontSize = oSketchText.Style.FontSize * 2
you could also define a TextStyle with the parameters you need, and set it to
oSketchText.Style = oMyTextStyle
or set FormattedText which is an XML format that specifies text.
you may have to take a look at API help for more details.
nickolas_jaderas
Thanks!
Byt I dont understand where I put in the "size"-code, I get it to work with:
        oSketchText.Style.FontSize = 30
But not the other way around.
/Nickolas
nickolas_jaderas
Got it to work with:
oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, "<StyleOverride FontSize='30'>" & itemNo & "</StyleOverride>")
 so now it works perfectly!
And I learned to use the API help 🙂
Many thanks!
