I would like to make stepfiles of all the parts that I have on my drawing. It is most likely that they are all flat patterns. I allready got the following code put together. could someone see where the hickup is?
C_schijf_txt = "C:\Inventor\Orderpath.txt" C_Schijf_Route = "C:\Inventor\Ordernummer.txt" Dim Cschijf_route As String Dim Kschijf As String = "K:\" Dim Ordernummer As String Dim Tek_Ordernummer As String Tek_Ordernummer = iProperties.Value("Custom", "02-Ordernummer") Tek_ordernummer_teknummer = iProperties.Value("Custom", "02-Tekeningnummer") MsgBox(Tek_Ordernummer) oRead = System.IO.File.OpenText(C_schijf_txt) Cschijf_route = oRead.ReadToEnd() ' CStr(Left(iProperties.Value("Project","Part Number"),4)) oRead.Close() MsgBox(Cschijf_route) If Cschijf_route.Contains(Tek_Ordernummer) Then Ordernummer = Tek_Ordernummer Else MsgBox("De ordernummers komen niet overeen, je zit in een verkeerd project." & vbLf & "Pas dit aan!") Exit Sub End If Dim Split() As String = Cschijf_route.Split("\") Dim Klantnaam As String Dim Jaartal As String Dim K_Schijfroute As String Klantnaam = Split(5) Jaartal = Split(6) K_Schijfklantmap = Kschijf & Jaartal & "\" & Klantnaam For Each Mapname As String In IO.Directory.GetDirectories(K_Schijfklantmap, Ordernummer & " " & "*", IO.SearchOption.AllDirectories) If Mapname.Contains(Ordernummer) Then 'The next line of code gets only file extensions from searched directories and subdirectories K_Schijfroute = IO.Path.GetFullPath(Mapname) 'writer.WriteLine(fName) 'MsgBox(Mapnaam) 'flocatie = IO.Path.GetDirectoryName(filename) 'MsgBox(flocatie) End If Next Dim Stepfile_Flatpatternmap As String = (K_Schijfroute & "\" & "02-Inkoop\" & "Teknr " & Tek_ordernummer_teknummer ) MsgBox(Stepfile_Flatpatternmap) Dim Yesnovraag As String = MessageBox.Show("Stepfile maken van de onderdelen?" & vbLf & "De stepfiles komen op de K-schijf onder de 01-Inkoop map.","Stepfile generator",MessageBoxButtons.YesNo) If Yesnovraag = vbNo Then Exit Sub Else If Not System.IO.Directory.Exists(Stepfile_Flatpatternmap) Then System.IO.Directory.CreateDirectory(Stepfile_Flatpatternmap) Else MsgBox("Zijn al stepfiles van gemaakt.") Exit Sub End If End If Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet ' select drawing views on active sheet Dim oDrawView As DrawingView For Each oDrawView In oSheet.DrawingViews Dim oModelDoc As Document = oDrawView.ReferencedDocumentDescriptor.ReferencedDocument Dim oViewModelName As String = oModelDoc.DisplayName Dim oFullFilePath As String = oModelDoc.FullFileName Dim oFolderPath As String = Left(oFullFilePath, (InStrRev(oFullFilePath, "\", -1, vbTextCompare) -1)) '' MessageBox.Show("DisplayName: " & oViewModelName) '' MessageBox.Show("FullFilename: " & oFullFilePath) '' MessageBox.Show("FolderPath: " & oFolderPath ) Dim oDoc As Document = ThisApplication.Documents.Open(oFullFilePath) ' auto = iLogicVb.Automation Try ' auto.RunRule(oDoc, sRuleName) iLogicVb.RunExternalRule( "AuTTeK\TDV\Save_as_stepfile") ' iLogicVb.Automation.RunExternalRule(oDoc,"Save_as_stepfile") Catch MessageBox.Show("Cannot find a rule with the name " & "Save_as_stepfile" & vbLf & "Please try again.", "Open and run") End Try Dim Stepfile_Flatpatternmap1 As String = (K_Schijfroute & "\" & "02-Inkoop\" & "Teknr " & Tek_ordernummer_teknummer ) Dim Posnr As String = iProperties.Value(oDoc.name,"Custom", "03-Posnr") Dim Hoofdtek As String = iProperties.Value(oDoc.name,"Custom", "03-Hoofdtekening") ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById _ ("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument _ , oContext, oOptions) Then oOptions.Value("ApplicationProtocolType") = 3 oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium ' Set export name of STEP file oData.FileName = (Stepfile_Flatpatternmap1 & "\" & Hoofdtek & "_" & Posnr &".ipt") oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext _ , oOptions, oData) End If ' End of export code *********************************************** ' Ask user if they want to open the export folder OpenFolder = MessageBox.Show("Export successful! " & _ "- open containing folder now?", "Cadline iLogic", _ MessageBoxButtons.YesNo, _ MessageBoxIcon.Question,MessageBoxDefaultButton.Button1) If OpenFolder = vbYes Then Process.Start("explorer.exe", ThisDoc.Path) Else ' User says continue 'Return End If Next
The problem starts when I open the files one by one and then need a Ipropertie in that file, but I cant get it because the rule is still in the "DWG" file.
