Create representation view in assembly
manu.marjanen
manu.marjanen
Is it possible to make code that create view representation in assembly level?
For example,
View representation name "Test" including parts "Part:1, Part:2, Part:3" are visibility.
JMGunnar
here one exampel  @manu.marjanen  ->
Start with all component visibility , Default design view
Best Regards Johan G
Class ThisRule
	Sub Main()
	Dim refs As New List(Of String)
		refs.Add("Part1:1")
		refs.Add("Part2:2")
		refs.Add("Part:3")
	CreateDesignViewWithComponents(refs, "Test", False)
	refs.Clear()
	refs.Add("Part:1")
	CreateDesignViewWithComponents(refs, "Test2", False)
	End Sub
	Public Sub CreateDesignViewWithComponents(RefChainList As List(Of String), nameOfDesignView As String, Optional createLoD As Boolean = False)
			Dim odoc As AssemblyDocument = ThisDoc.Document
			Dim oAssDef As AssemblyComponentDefinition = odoc.ComponentDefinition
			Dim dvrs As DesignViewRepresentations = oAssDef.RepresentationsManager.DesignViewRepresentations
			Dim currentDvrName As String = oAssDef.RepresentationsManager.ActiveDesignViewRepresentation.Name
			Dim dvr As DesignViewRepresentation
			Try
				dvrs.Item(nameOfDesignView).Delete
				dvr = dvrs.Add(nameOfDesignView)
			Catch
			End Try
			Dim ReturnedOcc As Inventor.ComponentOccurrence
			Dim occColl As ObjectCollection
			If ThisApplication Is Nothing Then
				occColl = ThisServer.TransientObjects.CreateObjectCollection
			Else
				occColl = ThisApplication.TransientObjects.CreateObjectCollection
			Dim item As String
			Dim oCompDef As Inventor.ComponentDefinition = odoc.ComponentDefinition
			'define the first level components collection
			Dim oCompOcc As Inventor.ComponentOccurrence
			'Turn off the visibility of parts in the top level assembly that don't contain the specified text string (StrInput1)
			For Each oCompOcc In oCompDef.Occurrences
					For Each item In RefChainList
						If oCompOcc.Name = item Then
							oCompOcc.Visible = True
							Try
								oCompOcc.SetDesignViewRepresentation("Drawing")
							Catch
							End Try
						  	Exit For
						Else
							oCompOcc.Visible = False
					Next
			Next
			dvr.Locked = True
			Dim LoDrs As LevelOfDetailRepresentations = oAssDef.RepresentationsManager.LevelOfDetailRepresentations
			Dim LoDr As LevelOfDetailRepresentation
			If createLoD = True Then
				Try
					LoDrs.Item(nameOfDesignView).Delete
					LoDr = dvr.CopyToLevelOfDetail
				Catch
				End Try
			dvrs.Item(currentDvrName).Activate
	End Sub
End Class
manu.marjanen
I do not quite understand everything. Can that be done somehow more simply?
TomaszDąbrowski
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oRef1 As String = "Part:1"
Dim oRef2 As String = "Part:2"
Dim oRef3 As String = "Part:3"
Try
oDoc.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Item("test").Activate
Catch
oDoc.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Add("test")
End Try
For Each oOcu As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
	If oOcu.Name <> oRef1 And oOcu.Name <> oRef2 And oOcu.Name <> oRef3 Then
		oOcu.Visible = False
	Else
		oOcu.Visible = True
	End if
	Next
