create part file with i logic code
Message 1 of 8
it is my code.
GoExcel.Open("C:\Users\a.khakbaz\Desktop\nozzle\Cube.xlsx", "Sheet1")
Dim sFilePath As String= ThisDoc.Path & "\"
Dim sNewName As String
CurrentFilename = ThisDoc.PathAndFileName(False)
For i=2 To 4
doc = ThisDoc.Document
sNewName=GoExcel.CellValue("A" & i)
Length = GoExcel.CellValue("B" & i)
width= GoExcel.CellValue("C" & i)
Height = GoExcel.CellValue("D" & i)
doc.saveas(sFilePath & sNewName & ".ipt",True)
Next i
iLogicVb.UpdateWhenDone = True
i send you cube.ipt and cube.xlsx
in This code i want for each row of excel, a part file with the name of  reading from column A (a1 or a2 or a3) is created and parameters (Lenght, Width and Height) changed.
BUT THE PROBLEM IS THAT a1.ipt and a2.ipt and a3.ipt created but with Length=width=Height=5mm. why my parameters do not change for a1 and a2??
Inventor 2016
Replies (7)
Message 2 of 8
danijel.radenkovic
Why should you not try iPart?
My opinion is that the best way to do it by Creating iPart.
Here is a link:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
iPart works like Family of similar members. You can easily switch between them as you can see on the image below.
Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Message 3 of 8
danijel.radenkovic
By the way,
Here is iLogic way.
GoExcel.Open(ThisDoc.Path & "\" & "Cube.xlsx", "Sheet1")
'CurrentFilename = ThisDoc.PathAndFileName(True)
For i=2 To 4
Length= GoExcel.CellValue("B" & i)
RuleParametersOutput() ThisDoc.Document.Update() ThisDoc.Document.saveas(sFilePath & sNewName & ".ipt",True) Next i
GoExcel.Close
Regards
Danijel
Message 4 of 8
Thanks for your reply,
but still a have problem,
Lenght, width and Height of the three parts (a1, a2 and a3) are 5mm. (Last row of the excel)
Why??
Message 5 of 8
danijel.radenkovic
Why??
 Probably you didn't copy whole code. Make sure that you need to have two lines marked with blue color. One is to update Rule parameters and other to update part.
For i=2 To 4
GoExcel.Close
I have recorded a video of test so you can see is it works as you wished or not.
Best regards
Danijel
Message 6 of 8
YOUR RIGHT...
THANK YOU
CAN YOU TAKE A LOOK AT THIS PROBLEM WHICH I POSTED RECENTLY
http://forums.autodesk.com/t5/inventor-customization/drawing-automatic/td-p/6061005
Message 7 of 8
i added below code to your code for opening a1 to a3 .ipt but it gives error
why?
For i=2 To 4
ThisDoc.Launch(sFilePath & sNewName & ".ipt")
Next i
Message 8 of 8
