Create or modify custom properties of children from assembly
peterjoachim
peterjoachim
After scouring through the forums I was able to piece together the code below (My coding skills are very weak). It works but needs some modifications I can't quite figure out.
'the document is being opened
Dim openDoc As Document = ThisDoc.Document
Dim ETOproset As PropertySet
Dim ETOProperty As Inventor.Property
Dim ETO As Double
Dim ETOHasDrawing As Boolean = False
'This code opens every document related to this assembly
For Each doc As Document In openDoc.AllReferencedDocuments
'This code allows loops to continue if the wanted parameters dont exist in the part or assembly
On Error Resume Next
ETOproset = doc.PropertySets.Item("Inventor User Defined Properties")
ETOproset.Add(ETOHasDrawing, "TotalETOHasDrawing")
Next
 In short, what I'm trying to do is, from a top level assembly, apply this...
iProperties.Value("Custom", "TotalETODrawing") = iProperties.Value("Project", "Part Number") & "-Sht1#J:\" & (Left(ThisDoc.FileName, 6)) & "\MECH\DETAILS\" & iProperties.Value("Project", "Part Number") & "-Sht1.pdf#"
iProperties.Value("Custom", "TotalETOHasDrawing") = True
...to all components that are NOT in a library. This would be applied at the component level so the part# would reflect each components part# and not the assembly part#. Also if those properties already exist on some components, I would like it to overwrite it with these new values.
Any help would be greatly appreciated.
peterjoachim
After reading a few Mod the Machine articles I've figured it out. Feel free to critique my code though as I'm very green.
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = kAssemblyDocumentObject Then
	For Each docFile In openDoc.AllReferencedDocuments
		If docFile.IsModifiable = True Then
			Dim customPropSet As PropertySet
			customPropSet = docFile.PropertySets.Item("Inventor User Defined Properties")
			Dim partNumber As String
			partNumber = docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
			Dim property1Name As String
			property1Name = "TotalETODrawing"
			Dim property1Value As String
			property1Value = partNumber & "-Sht1#J:\" & (Left(partNumber, 6)) & "\MECH\DETAILS\" & partNumber & "-Sht1.pdf#"
			Dim property2Name As String
			property2Name = "TotalETOHasDrawing"
			Dim property2Value As Boolean
			property2Value = True
			Try
				customPropSet.Item(property1Name).Value = property1Value
				Catch ex As Exception
				customProp = customPropSet.Add(property1Value, property1Name)
			End Try
			Try
				customPropSet.Item(property2Name).Value = property2Value
				customProp = customPropSet.Add(property2Value, property2Name)
			End Try
	Next
	Else
	MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
