Create new column in BOM automatic
buitrongcuongypbn2000
Hello everyone,
I have a problem about BOM in Inventor. I want to create some columns automatic by VBA code or something like that. If you have the solutions, you can share for me.
Thank you very much!
WCrihfield
Hi @buitrongcuongypbn2000.  We do not have control of the columns included in the assembly's BOM from Inventor's API/iLogic/VBA.  Another way to achieve what you seem to want would be to prepare the BOM the way you want it first, then export that customization out to an XML file.  Then when you want to use that customization again, import that exported XML file again.  Here is a very simple iLogic rule for either exporting or importing the BOM customization.  But you would have to change the specified file path & name to suit your specific needs.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oBOM As BOM = oADoc.ComponentDefinition.BOM
	Dim sBOMTemplate As String = "C:\Temp\MyBOMTemplate.xml"
	'oBOM.ExportBOMCustomization(sBOMTemplate)
	oBOM.ImportBOMCustomization(sBOMTemplate)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
