Create JPEG of Drawing (idw) through Inventor API
Message 1 of 23
I wanted to know how to create JPEG image of a drwing (idw) file in Inventor through Inventor API? Is there a way out?
I have even installed the "Export Viewable Files" from the http://www.kwikmcad.com site but am not able to automate it using API.
Can you help me out??
Ankit
Replies (22)
Message 21 of 23
The SaveAs method lets you save to other formats, but as you've mentioned,
you can't specify the size in that method. In order to specify size, you
must use SaveAsBitmap. Note that SaveAsBitmap does save to the format
specified in the file extension (as Teun mentioned).
Sanjay-
wrote in message news:5796695@discussion.autodesk.com...
Teun,
The VBA save in BMP with extension JPG.
Because I inform the extension wrong. Ok.
But the problem is a function SaveAsBitmap, is that where I define the
aspectratio.
If you try save in JPG with options (aspectioratio).
If use saveas only, no have teh same options.
Sorry my basic english.
Message 22 of 23
Crstiano
Other question is: After create the image file, I need rotate in case the Landscape for Portrait !!
Any ideia?
Cristiano Oliveira
ConsultCAD.com
Message 23 of 23
Tom.DiGregorio2DPCZ6
I know this is an old thread but seriously, how is it possible that Inventor does not have a function to save a sheet as an image, NOT A SCREEN SHOT.
Have to save as PDF then using Acrobat save as image.
