Create Hole Table/Table through i-logic
gopinathmY575P
gopinathmY575P
Hello Team,
I need help in creating hole table/custom table through ilogic.
ryan.rittenhouse
What do you need help with? The easy way to add one is through Sheet.HoleTables.Add. you send it a view from the sheet, a Point2d to locate it, and a hole style and it does most of the heavy lifting. If you're running into trouble post your code and the errors you are getting and we can take a look.
If this solved your problem, or answered your question, please click Accept Solution.
gopinathmY575P
Whatever you mentioned will work for vba, but my need is through i-logic . as per my exploration there is no inbuilt snippets for hole tables through ilogic, thats why i raised this.
marcin_otręba
it works in ilogic as well:
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
ryan.rittenhouse
iLogic is essentially VBA with some added wrappers. We do all of our print automation in straight iLogic. If you need specific help with any part of it, we can work to clarify things.
gopinathmY575P
