Create hole in content center pipe in an assembly
jroyse
jroyse
I am new to ilogic. I have gotten my code to place and change the size of pipe from Content Center. I now need to add a hole through the side of the pipe depending on what the user selects in the form. Is it possible to start a sketch and add a hole with ilogic? Thanks
theo.bot
@jroyse ,
Yes you can, but there are no standard ilogic snippets for that. Meaning you have to use the Inventor API to create your code. Take a look at the API help to find more info and samples: Inventor 2023 Help | Sketches | Autodesk
Inventor 2023 Help | Hole Feature - Through holes (RegularAndTapped) | Autodesk
A.Acheson
Here is a sample , I have left in some comments so you can see how it is working. It gets rather complicated quickly with the need for proxies etc.
Approx Layout:
1. Occurence
2. PartDef
3. ProxyWorkPlane (Part)
4. AssemblySketch
5. SketchPoint(HoleCenter)
6. SketchHolePlacementDefinition
6. HoleFeature
Dim oAssyDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
	Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
    Dim oOcc As ComponentOccurrence = oCommandMgr.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select Part Occurrence")
	MessageBox.Show(oOcc.Name, "Occurrence Name")
	Dim oPartDef As PartComponentDefinition = oOcc.Definition
	' Select the plane we want to work with
	Dim oWPlane1 As WorkPlane = oPartDef.WorkPlanes.Item("XZ PLANE")
	' Need a proxy to identify where the workplane is located in assembly space.
    Dim oWPlane1Proxy As WorkPlaneProxy
	oOcc.CreateGeometryProxy(oWPlane1, oWPlane1Proxy)
	'Dim oWorkPlaneProxy As WorkPlaneProxy = oCommandMgr.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select Part Workplane")
	' Create a new sketch on the work plane proxy.
	Dim oSketch As PlanarSketch = oAssyDef.Sketches.Add(oWPlane1Proxy)
    'Dim oSketch As PlanarSketch = oCommandMgr.Pick(SelectionFilterEnum.kSketchObjectFilter, "Select Part Sketch")
	' Create a new object collection for the hole center points.
    oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oPoint As Point = oPartDef.WorkPoints("Center Point").Point
	' Set a reference to the transient geometry object.
	Dim oTransGeom As TransientGeometry = ThisApplication.TransientGeometry
	' Add a point as hole center.
    oHoleCenters.Add (oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(oPoint.X-1, oPoint.Y)))
   'oHoleCenters.Add(oSketch.SketchPoints(1))' Add from existing sketch
	Dim oHoleFeatures As HoleFeatures = oAssyDef.Features.HoleFeatures
 	Dim oSketchHolePlacementDef As SketchHolePlacementDefinition = oHoleFeatures.CreateSketchPlacementDefinition(oHoleCenters)
  	Dim oHoleFeature As HoleFeature = oHoleFeatures.AddDrilledByThroughAllExtent(oSketchHolePlacementDef, 0.8, kNegativeExtentDirection)
Regards
Alan
jroyse
@A.Acheson  that worked great! After a few tweaks it's doing what I need it to. Thank you!
