Create DXF from assembly and include 'Revision' and parameter 'thickness'
Message 1 of 14
Hi, I have some code from others contributions that has helped me to create a dxf from parts in assemblies and to export parameters, however after much trying I have to concede I don't have any real programming skills to bring all the code together I need.
This will greatly help my clients fabrication department in generating dxf's , managing dxfs and in nesting dxfs.
I need code to take part HM12345.ipt and generate HM12345_(Revision)_(Thickness), from an open assembly.
Revision comes from the property 'Revision'
Thickness comes from the parameter 'Thickness' in sheet metal parts
I also need to set every checked out part in the assembly to export the parameter 'Thickness' prior to running the main routine.
My final dxf filename would look like this.  HM12345_00_3.0mm.dxf
Also in the routine attached I think the code is getting the revision number of the assembly not of each part.
I need the revision number of each part to appear in the file name of each part.
So the workflow would be
1. Set all parts  parameter 'Thickness' set to export in open assembly
2. Create Sub folder with same number as Assembly and the text DXF, ie HM12345_DXF
3. Generate DXF's with concatenated part number as above in that folder
If someone could help it would be greatly appreciated
Thanks Peter
Replies (13)
Message 2 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Hoping that below iLogic may be helpful to accomplish your task.
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & "_DXF"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
	If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
		'check that model is saved
		If(System.IO.File.Exists(iptPathName)) Then
			Dim oPartDoc As PartDocument
			oPartDoc = ThisApplication.Documents.Open(iptPathName, True)
			oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
			Try
				oRevName =iProperties.Value(oFileName, "Project", "Revision Number")
				Dim oCompDef As SheetMetalComponentDefinition
				oCompDef = oPartDoc.ComponentDefinition
				Dim oThick As Double
				oThick = oCompDef.Parameters.UserParameters.Item("Thickness").ModelValue
				oDataMedium.FileName = oFolder & "\" & oFileName &  "_"&oRevName & "_" & oThick.ToString() & "mm" & ".dxf"
				If oCompDef.HasFlatPattern = False Then
					oCompDef.Unfold
				Else
					oCompDef.FlatPattern.Edit
				Dim sOut As String
				sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR​OFILE"
				oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
				'just for check its works coretcly
				'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
				'MessageBox.Show(i,"title",MessageBoxButtons.OK)
				'If i=2 Then
				'Exit Sub
				'End If
				oCompDef.FlatPattern.ExitEdit
			Catch
			End Try
			oPartDoc.Close
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 14
Hi, I get the following error when I run this routine. Any help would be greatly appreciated.
Thanks Peter
Message 4 of 14
Error.JPGHi, I get the following error when I run this routine, any help would be greatly appreciated. Thanks Peter
Message 5 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Please provide sample assembly with part files to test the behavior and make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 14
firelinsgs
Try this one. We can also add counting the parts per assembly and write the Quantity to name file.
Sub Main
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Export(oDoc)
		Exit Sub
	Cycle(oDoc)
End Sub
Sub Cycle(oDoc As AssemblyDocument)
	For Each aDoc As Document In oDoc.ReferencedDocuments
		If aDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Export(aDoc)
		ElseIf aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Cycle(aDoc)
	Next
End Sub
Sub Export(oDoc As PartDocument)
	Dim FName As String = GetFName(oDoc.FullFileName)
	Dim sPN As String = iProperties.Value(FName, "Project", "Part Number")
	Dim Rev As String = iProperties.Value(FName, "Project", "Revision Number")
	Dim oCD As SheetMetalComponentDefinition = oDoc.ComponentDefinition
	If Not oCD.HasFlatPattern Then
		oCD.Unfold()
		oCD.FlatPattern.ExitEdit()
	If Rev = Nothing Then Rev = "00"
	Dim dThick As Double
	Try
		dThick = Math.Round(oCD.Parameters("Tloušťka").Value * 10, 1)
	Catch
		Exit Sub
	End Try
	If dThick < 0.05 Then Exit Sub
	Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2013&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ARC_CENTERS"
	FName = oDoc.FullFileName
	Dim FNP As Integer = InStrRev(FName, "\", -1)
	Dim sPath As String = Left(FName, FNP)
	FNP = InStr(sPath, "\")
	sPath = "C:\DXF" & Mid(sPath, FNP)
	If Not System.IO.Directory.Exists(sPath) Then System.IO.Directory.CreateDirectory(sPath)
	Dim sNewName As String = sPath & sPN & "_" & Rev & "_" & CStr(dThick) & "mm" & ".dxf"
	oCD.DataIO.WriteDataToFile(sOut, sNewName)
End Sub
Function GetFName(FullName As String) As String
	Dim FNP As Integer = InStrRev(FullName, "\", - 1)
	Dim FName As String = Mid(FullName, FNP + 1, Len(FullName) - FNP)
	Return FName
End Function
Message 7 of 14
Hi, Here is the test assembly.
It should create two DXFs,.
My other o routines run with this assy
The routine runs, but it does not seem to create the dxf's and it does not set the  thickness parameter to 'export'
Thank you very much for your help
Kind Regards
Peter
Message 8 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
For some reason, assembly attachement is missing in previous post.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 14
Hi, I added as a zip file on the attachments tab
Hope it come thru this time
Thanks Peter
Message 10 of 14
Thanks Peter
Message 11 of 14
Thanks Peter
Message 12 of 14
Hi, Thanks for that.
I ran the routine, there is no visual indication that the routine has run. I checked DXF creating under the Vault workspace and there is no created DXFs.
I ran my old routine and it ran ok.
I checked the parts after running the routine the parameter 'thickness' had not been set to export.
So it is not working for me at the moment.
Thanks Peter
Message 13 of 14
firelinsgs
Just change this row
		dThick = Math.Round(oCD.Parameters("Thickness").Value * 10, 1)
 In this row is path to dxf file. Change it as needed
And what you mean by "set thickness to export"??
Message 14 of 14
Great, this works well.
Thanks for your help, this is a great start for us.
Greatly appreciated.
Kind Regards Peter
