Hello all,
Below is a code that creates a ipt file for whatever number tags i choose to. It works good but i would like to create a drawing with every part it makes with just the front face view. Ill also attach the template ipt file where it creates the parts from. If anyone can help that would be great. Thanks
Feature.IsActive("___0") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___1") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___2") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___3") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___4") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___5") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___6") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___7") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___8") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("___9") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__0_") = False Feature.IsActive("__1_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__2_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__3_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__4_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__5_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__6_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__7_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__8_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("__9_") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_0__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_1__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_2__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_3__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_4__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_5__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_6__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_7__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("_8__") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("0___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("1___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("2___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("3___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("4___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("5___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("6___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("7___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in Feature.IsActive("8___") = False d35 = 0.25 in d37 = 0.00 deg d36 = 1 in For i = 4 To 4 x = i - 1 If x = -1 Feature.IsActive(i & "___") = True Else Feature.IsActive(i & "___") = True Feature.IsActive(x & "___") = False End If For z = 0 To 7 y = z - 1 If y = -1 Feature.IsActive("_" & z & "__") = True Else Feature.IsActive("_" & z & "__") = True Feature.IsActive("_" & y & "__") = False End If If z = 4 Feature.IsActive("_" & z & "__") = True Feature.IsActive("__0_") = True Feature.IsActive("___0") = True NewFileName = ThisDoc.Path & "\" & i & z & a & c & ".ipt" ThisDoc.Document.SaveAs(NewFileName, True) Else For a = 0 To 9 b = a - 1 If b= -1 Feature.IsActive("__" & a & "_") = True Else Feature.IsActive("__" & a & "_") = True Feature.IsActive("__" & b & "_") = False End If For c = 0 To 9 d = c - 1 If a = 0 And c = 0 End If If d = -1 Feature.IsActive("___" & c) = True NewFileName = ThisDoc.Path & "\" & i & z & a & c & ".ipt" ThisDoc.Document.SaveAs(NewFileName, True) Else Feature.IsActive("___" & c) = True Feature.IsActive("___" & d) = False NewFileName = ThisDoc.Path & "\" & i & z & a & c & ".ipt" ThisDoc.Document.SaveAs(NewFileName, True) End If If c = 9 And a = 9 Feature.IsActive("___" & c) = False Feature.IsActive("__" & a & "_") = False End If If c = 9 Feature.IsActive("___" & c) = False End If Next Next End If Next Next
