Create customized TXT from Part List and Sheet - IV 2011 - VBA
ladimirabdala
ladimirabdala
Hello guys, how are you doing?
I need do a customized TXT file create with some data the Part List and some data from Sheet.
Our ERP software read this TXT and register the Assemby in our database.
The final TXT result must be like red lines below:
C 100000-GS-005  100000-GS-005  5 Conjunto placas                     CJ
E 100000-GS-005  100000-GS-056  01
E 100000-GS-005  100000-GS-055  01
The columns where each text starts must be column 1, column 3, column 18, column 33, column 71.
Letter "C" means that this line is an Assembly
Letter "E" means that is a part.
Number "5" in the first line not change.
The number "01" in the lines 2 and 3, means the quantity of each part on the assembly.
Any comments, sugestions and questions will be welcome.
Than you.
Ladimir Abdala
BRAZIL
you can use next VBA code. You still need to add the assy info and export to txt file (isn't hard to do). You also need to change the delimiter I guess (ERP probably expects comma, tab, fixed width or other delimiter). Just give it a try.Smiley Happy
Have fun
Public Sub BOMQuery()
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim FirstLevelOnly As Boolean
    If MsgBox("First level only?", vbYesNo) = vbYes Then
        FirstLevelOnly = True
    Else
        FirstLevelOnly = False
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set whether first level only or all levels.
    If FirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = True
    Else
        oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    Set oBOMView = oBOM.BOMViews.Item("Structured")
    Debug.Print "Item"; Tab(15); "Quantity"; Tab(30); "Part Number"; Tab(70); "Description"
    Debug.Print "----------------------------------------------------------------------------------"
    'Initialize the tab for ItemNumber
    Dim ItemTab As Long
    ItemTab = -3
    Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
    ItemTab = ItemTab + 3
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.Count
        ' Get the current row.
        Dim oRow As BOMRow
        Set oRow = oBOMRows.Item(i)
        'Set a reference to the primary ComponentDefinition of the row
        Dim oCompDef As ComponentDefinition
        Set oCompDef = oRow.ComponentDefinitions.Item(1)
        Dim oPartNumProperty As Property
        Dim oDescripProperty As Property
        If TypeOf oCompDef Is VirtualComponentDefinition Then
            'Get the file property that contains the "Part Number"
            'The file property is obtained from the virtual component definition
            Set oPartNumProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Part Number")
            'Get the file property that contains the "Description"
            Set oDescripProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Description")
            Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
                oPartNumProperty.Value; Tab(70); oDescripProperty.Value
        Else
            'The file property is obtained from the parent
            'document of the associated ComponentDefinition.
            Set oPartNumProperty = oCompDef.Document.PropertySets _
            Set oDescripProperty = oCompDef.Document.PropertySets _
           Debug.Print oCompDef.Document.FullFileName
            'Recursively iterate child rows if present.
            If Not oRow.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
    Next
    ItemTab = ItemTab - 3
End Sub
mrattray
This is what I use. This gets called from iLogic and reads the parts list thenwrites the information in a matrix of hidden iProperties. I then write the properties to excel using iLogic. This code hides detail parts and excludes them from the matrix because I use another macro that handles them a little differently (reads from the title blocks). I then have an excel macro that formats the information for printing and uploading to our ERP.  The previous posters solution is probably a lot simpler but I need a lot of data to be written in multiple places.  I can supply the other modules (including the excel part) if you think this is more of what you need.
Public Sub PartsListQuery()
'This sub is designed to read stock part lists and write them to a drawings iProperties in an indexed format (i.e. 1,1 = qty per asm for part 1)
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim invCustomPropertySet As PropertySet
    Dim invCustomPropertySetC As PropertySet
    Set invCustomPropertySetC = oDrawDoc.PropertySets.Item("User Defined Properties")
   ' Dim oPropSets As PropertySets
   ' Set oPropSets = oDrawDoc.PropertySets
   ' Call oPropSets.Add("AutoBOM")
    Dim rowNum As Integer
    Dim oPartList As PartsList
    Set oPartList = oDrawDoc.activeSheet.PartsLists.Item(1)
    Dim PartCount As Integer
    Dim invProperty As Property
    Dim oRow As PartsListRow
    Dim oCell As PartsListCell
    Dim partQty As Integer
    Dim i As Integer
    Dim j As Integer
    Dim seq As String
    If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
    MsgBox ("You must have a drawing document active")
    Exit Sub
'oPartList.Sort ("STOCK SEQUENCE NUMBER")
'oPartList.Renumber
'oPartList.SaveItemOverridesToBOM
On Error GoTo code:
    Call CreateAutoBOMPropertySet
    Set invCustomPropertySet = oDrawDoc.PropertySets.Item("AutoBOM")
    GoTo code2:
code:
'MsgBox ("1")
On Error GoTo 0
    Err.Clear
'MsgBox ("2")
code2:
On Error GoTo noList:
    PartCount = oPartList.PartsListRows.count
If PartCount = 0 Then
PartCount = MsgBox("Parts list is empty!", vbCritical, "Error")
Exit Sub
'MsgBox (PartCount)
    rowNum = 0
    partQty = 0
'On Error GoTo noProp:
'On Error GoTo 0
On Error Resume Next
    For i = 1 To PartCount
        Set oRow = oPartList.PartsListRows.Item(i)
        Set oCell = oRow.Item(2)
        'MsgBox ("4i" & i)
            If oCell.Value = "STK" Or oCell.Value = "FA" Or oCell.Value = "PP" Then
              oRow.Visible = True
              rowNum = rowNum + 1
              ' Iterate through each column in the row.
            For j = 1 To 10
                ' Get the current cell.
                Set oCell = oRow.Item(j)
       '         MsgBox ("i" & i & "5j" & j)
                Set invProperty = invCustomPropertySet.Add(oCell.Value, rowNum & "," & j)
               ' invCustomPropertySet.Item(rowNum & "," & j).Value = oCell.Value
        '        MsgBox ("i" & i & "6j" & j)
            Next j
            ElseIf oCell.Value <> "" Then
                Set oCell = oRow.Item(10)
                seq = oCell.Value
         '       MsgBox ("5i" & i)
                Set oCell = oRow.Item(1)
          '      partQty = partQty + 1
          '      MsgBox ("6i" & i)
                Set invProperty = invCustomPropertySet.Add(oCell.Value, seq & " qty")
                invCustomPropertySetC.Item(seq & " qty").Value = oCell.Value
           '     MsgBox ("7i" & i)
                invCustomPropertySet.Item(seq & " qty").Value = oCell.Value
                oRow.Visible = False
            '    MsgBox ("8i" & i)
            Else
    Next i
'On Error GoTo noProp2:
'On Error GoTo 0
invCustomPropertySet.Item("partQty").Value = rowNum
'invCustomPropertySet.Item("partCount").Value = PartCount
Set invProperty = invCustomPropertySet.Add(rowNum, "partQty")
'Set invProperty = invCustomPropertySet.Add(PartCount, "partCount")
Exit Sub
noList:
MsgBox ("parts list not found!")
Exit Sub
noProp:
MsgBox ("Custom properties not found!")
Exit Sub
noProp2:
MsgBox ("Custom properties not found! 2nd section.")
End Sub
Mike (not Matt) Rattray
