Create Custom Table
Create Custom Table
engineeringSEZWD
Create Custom Table
engineeringSEZWD
Hello All,
does anyone could help to create a custom table that copy iproperty (information) of each sheet and create the table.
I have a 2D file of endless sheet. so need to have a loop ilogic in all sheet
each sheet has the property
name of the colum (iproperty name)
Drawing No. - (Property Fied name of property is DWG No)
No. Sheet No, (find in Sheet properties Sheet number)
Drawing Drescription- (Property Fied name of property is Sheet Description)
this table I have to do it manually and it change a few time during desing.
however I cant use boom list because they are not in a assembly, they are the names of each sheet.
thank you
cidhelp
Hi @engineeringSEZWD ,
I have created an iLogic rule that creates the table on the first sheet.
It tries to get the model document from the first view on every sheet. Than the 2 user defined iProperties are read.
engineeringSEZWD
@cidhelp
Thank you for all your help. The iLogic rule worked partially.
It successfully created a table with the number of pages, but it didn’t capture the drawing number or the drawing description.
I’ve attached a picture showing where I enter those names.
Currently, I need to go into every sheet, right-click on the field text, and manually edit the property field. So I believe that the illogic need to get those names from same place.  I am not sure that if is already code for that.
thank you 
cidhelp
@engineeringSEZWD ,
I thought that DWG No and Drawing Description are userdefined iProperties from the models.
But they are prompted text fields at your title block?
Can you share a drawingfile to adjust the rule?
cidhelp
@engineeringSEZWD ,
I have created a drawing with prompted textboxes in titleblock and changed the rule.
Now it reads the result text from the textboxes.
cidhelp
@engineeringSEZWD,
sorry, I forgot the sheet no, please try this rule.
engineeringSEZWD
Thank you, very much @cidhelp
The sheet description didn’t work because the code used Drawing Description instead of Sheet Description, I change manually here.
rather than that Worked perfect fine
@cidhelp  yeh in general the description comes from 3D file, however this is a civil drawing, so sometimes I have to create a drawing with picutres,, notes, that are not link with 3D model. So for this case we write the description and part number manually on the field text
many thanks
