Create centerline on a plate with iLogic
sbcJLYKK
Message 1 of 8
sbcJLYKK
Hi
I hope you can help me.
I have this iLogic code
'Set a reference to the active drawing document
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheets = oDoc.Sheets
oSheet = oDoc.ActiveSheet
For Each oSheet In oSheets
oViews = oSheet.DrawingViews
For Each oView In oViews
Dim oCenterline As AutomatedCenterlineSettings
oView.GetAutomatedCenterlineSettings(oCenterline)
oCenterline.ProjectionParallelAxis = True
oView.SetAutomatedCenterlineSettings(oCenterline)
Dim resultCenters As ObjectsEnumerator
resultCenters = oView.SetAutomatedCenterlineSettings(oCenterline)
Next
Next
I have this plate, please see attachment picture
Where I want a centerline, vertical and horizontal (the red lines) to illustrate what I mean
I can not get the code to work, so I hope I can get help from you.
Yours sincerely
Steffen
Replies (7)
Message 2 of 8
WCrihfield
Hi @sbcJLYKK.  Unless the mostly rectangular cutout in the middle of the part was made with a sheet metal punch tool, you are most likely not going to get a Centermark or Centerline at its center using the automated centerline settings tool.  If the part was modeled centered on the origin planes, and aligned parallel/perpendicular with the origin planes you could turn the visibility of those origin planes on within the view to form the center lines similar to what you seem to be wanting.  To do something like that by code you could use the DrawingView.SetIncludeStatus(oWorkPlane1) method.  That will both 'include' the work plane, but also set its visibility to True.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
sbcJLYKK
Thank you for your reply😀.
I nede a little more help.
 I've been working with iLogic for about 14 days, so I'm still a beginner
I need a little more help. I did do a workplane as described
Where should I insert DrawingView.SetIncludeStatus(oWork_Plane_Horisontal) in The code
Sincerly Steffen
Message 4 of 8
WCrihfield
Hi @sbcJLYKK.  Sure.  Here is an example of an iLogic rule for the task I mentioned (including the two WorkPlanes in the view).  In this example, I have eliminated the loop of each sheet, and eliminated the loop of each view on each sheet, because this bit of code will only work on specific views that are oriented correctly with the right two work planes.  Only the two work planes that are perpendicular to the view will show properly as lines in the view.  I don't clearly recall right now, but I believe that trying to include the other work plane that is flat with the view may throw an error, because it won't produce any new geometry in the view.  Anyways, this example shows the basic process of how to do this specific task for a drawing view.  I included several lines of comments within the code too, in order to help a bit.  You may need to change the number 1 to a different number if the first view on the sheet is not the right one.  Or we may need to change how we are specifying which view to target.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
'specify which view to act upon
'you will likely only want to do this with a single view
'in this example, I'm just specifying the first view that was placed on this sheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
'get the model document being referenced by this view
Dim oModel As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
'a generic Document doesn't have WorkPlanes, only parts & assemblies do
'so in order to maintain 'intellisense' recognition going forward
'we must identify the document's specific type, then create that type of variable
'set its value, then work from that new document variable to get the WorkPlanes
If oModel.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
	Dim oPDoc As PartDocument = oModel
	Dim oWPlanes As WorkPlanes = oPDoc.ComponentDefinition.WorkPlanes
	oYZPlane = oWPlanes.Item("YZ Plane")
	'oXZPlane = oWPlanes.Item("XZ Plane")
	oXYPlane = oWPlanes.Item("XY Plane")
	'only include the two planes that are perpendicular to this view
	'which ever two they may be for your case
	oView.SetIncludeStatus(oYZPlane, True)
	oView.SetIncludeStatus(oXYPlane, True)
Wesley Crihfield
Message 5 of 8
sbcJLYKK
Hi
Many thanks for your help :).
It's really nice of you.
I have inserted the code as follows:
Dim oWPlanes As WorkPlanes = oPDoc.ComponentDefinition.WorkPlanes oYZPlane = oWPlanes.Item("YZ Plane")
oView.SetIncludeStatus(oXZPlane, True)
I have, of course, read the remarks, but I got an error
Message 6 of 8
WCrihfield
OK.  I could not tell what the error message said, because it was in a language I don't understand, but I was able to download the part and drawing files, and open them OK.  I had to modify the code very slightly, because one of the origin work planes I was using was the wrong one.  So, I simply got rid of the third work plane line of code, then un-commented the second one, then fixed the one 'SetIncludeStatus' line to the correct variable.  Then it worked just as planned.
Here is the exact code I used within a local iLogic rule (saved within the drawing document) and it ran perfectly for me.
Because the first DrawingView just happened to be the main front view on the drawing, and the two WorkPlanes in the model that are perpendicular to that front view in the part are the two that we want to work with here.
Wesley Crihfield
Message 7 of 8
WCrihfield
There are several ways to specify exactly which view you want to target, and since we usually want to do it by view name, here is the same iLogic rule that includes a way to get the view by its name.  This is the long way, using Inventor API code, instead of the iLogic shortcut snippet way.  It also worked just fine.
For Each oDView As DrawingView In oSheet.DrawingViews
	If oDView.Name = "Front_View" Then
		oView = oDView
Next
If oView Is Nothing Then
	MsgBox("A DrawingView named 'Front_View' was not found. Exiting rule.", vbCritical, "")
	Exit Sub
Wesley Crihfield
Message 8 of 8
sbcJLYKK
Many thanks for your help.
It's really kind of you.
It works now 🙂
