Create Buttons in RIBBON for many .ivb files
murugasubi
murugasubi
I have many VB macros (.ivb) for inventor projects. I want to add buttons for all the macros in RIBBON. The default.ivb allowing me to add only one macro file(default.ivb only). I want to add 10 Buttons in ribbon for 10 different VB macros,. How to load and run many .ivb files.
Its impossible to club all the .ivb files to single ivb file (default.ivb). Please advice.
In the customize user command window, default.ivb macro file procedure only coming.
Murugan
DeptaM
murugasubi
Hi, Thanks for your Reply..
Actually, I want to create buttons for VBA macros (.ivb). I tried with button constructor, it's asking to load external ilogic rule files only.. Now allowing to load (*.IVB) files.
Murugan
JelteDeJong
I created the addin "Button constructor". Initially, I planned to add support for VBA. But this is what Autodesk writes about VBA:
"For security reasons, the Microsoft VBA module is not included in the Inventor installer. It has a dependency on the Visual Studio 2010 (VC10) runtime, which Microsoft will not support after July 2020."
and
"As an alternative to VBA, consider using Inventor’s iLogic capability. It provides access to the Inventor API using VB.NET."
That sounds to me like the end of VBA and not something that I should put any effort in. Maybe it's for you also a reason to reconsider using VBA
Jelte de Jong
Blog: hjalte.nl - github.com
murugasubi
Oh... it's ok. Actually,  I am also trying to do all using ilogic.  Thank you JelteDeJong.
