Create Angle Dim Like This?
Curtis_Waguespack
Consultant Consultant
Curtis_Waguespack
Does anyone know what we need to do to get the "alternate angle" or whatever it is called?
see the attached 2024 drawing for an example.
Thanks!
Curtis
Trying to get this result using the code below:
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim VIEW3 = Sheet_1.DrawingViews.ItemByName("VIEW2")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
Dim Bottom = VIEW3.GetIntent("Bottom")
Dim ChamferFace = VIEW3.GetIntent("ChamferFace")
Dim PointOnSheet As DocumentUnitsPoint2d = ThisDrawing.Geometry.Point2d(3.4, 5.5)
Dim angDim1 = genDims.AddAngular("Angular Dim 1", PointOnSheet, Bottom, ChamferFace)
But I'm getting this result:
g.georgiades
Edit: actually the AddAngular has an optional parameter to specify to use the quadrant directly.
Function AddAngular (
	name As String,	textOrigin As AngularDimensionTextPositionSpec,	intentOne As GeometryIntent,
	Optional intentTwo As GeometryIntent = Nothing,
	Optional intentThree As GeometryIntent = Nothing,
	Optional arrowHeadsInside As Boolean = true,
	Optional useQuadrant As Boolean = true,
	Optional oppositeAngle As Boolean = false,
	Optional dimensionStyle As DimensionStyle = Nothing,
	Optional layer As Layer = Nothing
) As IManagedAngularGeneralDimension
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=c0a7eb37-0d59-962c-56f5-aef421470772
angDim1.UseQuadrant = False
You may have to create the dimension with the text centered, set the quadrant off, then move the text to the side.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=AngularGeneralDimension_UseQuadrant
Curtis_Waguespack
 Thanks! @g.georgiades
I think that was what I was missing.
Here's what worked with the example I posted.
Dim VIEW2 = Sheet_1.DrawingViews.ItemByName("VIEW2")
Dim Bottom = VIEW2.GetIntent("Bottom")
Dim ChamferFace = VIEW2.GetIntent("ChamferFace")
ThisApplication.DrawingOptions.CenterDimensionText = True
Dim PointOnSheet As DocumentUnitsPoint2d = ThisDrawing.Geometry.Point2d(3.4, 6)
MsgBox("pause to observe original position", , "iLogic")
'get API object for the dim
Dim angDim As AngularGeneralDimension = angDim1.NativeEntity
'get units conversion
Dim UOM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
oConverson = UOM.ConvertUnits(1,  UOM.LengthUnits,UnitsTypeEnum.kDatabaseLengthUnits)
PointOnSheet = ThisDrawing.Geometry.Point2d(3.4, 5.5)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim NewPoint As Point2d = oTG.CreatePoint2d(PointOnSheet.X * oConverson, PointOnSheet.Y * oConverson)
angDim.UseQuadrant = False
'change position of the dim text
angDim.Text.Origin = NewPoint
