Try this one below. There's an example for using TextBoxes, ComboBoxes, Labels and Buttons. Let me know if you need something else (more).
Imports System
AddReference "System.Drawing.dll"
Imports System.Windows.Forms
Sub Main()
CreateForm("MyForm")
MF.ShowDialog()
MsgBox("ComboBox one value: " & CB(0).Text & vbNewLine & "ComboBox two value: " & CB(1).Text & _
vbNewLine & "TextBox one value: " & TB(0).Text)
End Sub
Private MF As Form
Public CB(0) As ComboBox
Public TB(0) As TextBox
Private Sub CreateForm(Optional Name As String = vbNullString)
MF = New Form
MF.Text = Name
MF.AutoScaleMode = AutoScaleMode.None
MF.Size = New Drawing.Size(300, 300) 'Width, Heigth
MF.MinimumSize = MF.Size
MF.MaximumSize = MF.Size
MF.Font = New Drawing.Font(MF.Font.FontFamily, 10)
MF.MaximizeBox = False
MF.MinimizeBox = False
MF.ShowIcon = False
MF.SizeGripStyle = SizeGripStyle.Hide
MF.StartPosition = FormStartPosition.CenterScreen
AddLabel(5, 5, "Paramter One")
AddLabel(5, 40, "Paramter Two")
AddCB(120, 5, {"Option one", "Option two"}, 150)
AddCB(120, 40, {"Option three", "Option four"}, 150)
AddTB(120, 75, "SomeText", 150)
AddExitButton()
End Sub
Private Sub AddLabel(PosX As Integer, PosY As Integer, Caption As String, Optional Width As Integer = 100)
Dim LC As Integer = MF.Controls.Count + 1
Dim L1 As New Label
L1.Name = "L" & LC
L1.Location = New Drawing.Point(PosX, PosY)
L1.Text = Caption
L1.Width = Width
MF.Controls.Add(L1)
End Sub
Private Sub AddTB(PosX As Integer, PosY As Integer, Optional Caption As String = vbNullString, Optional Width As Integer = 100)
Dim LC As Integer = TB.Length - 1
If Not TB(LC) Is Nothing Then
LC = LC + 1
ReDim Preserve TB(LC)
TB(LC) = New TextBox
TB(LC).Location = New Drawing.Point(PosX, PosY)
TB(LC).Name = "TB" & LC
TB(LC).Text = Caption
TB(LC).Width = Width
MF.Controls.Add(TB(LC))
End Sub
Private Sub AddCB(PosX As Integer, PosY As Integer, Values() As String, Optional Width As Integer = 100)
Dim LC As Integer = CB.Length - 1
If Not CB(LC) Is Nothing Then
LC = LC + 1
ReDim Preserve CB(LC)
CB(LC) = New ComboBox
CB(LC).Location = New Drawing.Point(PosX, PosY)
CB(LC).Name = "CB" & LC
CB(LC).Width = Width
For Each Value As String In Values
CB(LC).Items.Add(Value)
Next
MF.Controls.Add(CB(LC))
End Sub
Private Sub AddButton(PosX As Integer, PosY As Integer, Caption As String)
Dim BT As New Button
BT.Name = "BT" & LC
BT.Location = New Drawing.Point(PosX, PosY)
BT.Text = Caption
MF.Controls.Add(BT)
End Sub
Private Sub AddExitButton()
BT.Name = "BT_Exit"
Dim PosX As Integer = MF.Width - (BT.Width * 1.3)
Dim PosY As Integer = MF.Height - (BT.Height * 3)
BT.Text = "OK"
MF.Controls.Add(BT)
AddHandler BT.Click, AddressOf Me.ExitButtonClick
End Sub
Private Sub ExitButtonClick()
MF.Close()
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
