Create a sketch on a certain face in a part with iLogic
RajivAngoelal
RajivAngoelal
Hello guys,
I want to make a code that "detects" a named face and create a sketch on that face.
I have a code, but i have to click the face to create a sketch.
The code:
oAssDoc = ThisApplication.ActiveDocument
oAssDef = oAssDoc.ComponentDefinition
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face ")
'make sure it is a planar face
If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
oPlanarSurface = oFace.Geometry
'add a sketch
oSketch = oAssDef.Sketches.Add(oFace)
'trying to choose an appropriate point
'assume this planar face has one edge loop only
oEdgeLoop = oFace.EdgeLoops(1)
oMinPt = oEdgeLoop.RangeBox.MinPoint
oMaxPt = oEdgeLoop.RangeBox.MaxPoint
CenterPt = ThisApplication.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
Else
Is it possible to detect the ‘face0’ in the named geometry(without extra clicking) and create a sketch on that face?
Help is much appreciated 🙂
JelteDeJong
did you see this post about getting a named face?
https://forums.autodesk.com/t5/inventor-customization/where-is-new-feature-face-name-in-inventor-201...
Jelte de Jong
Blog: hjalte.nl - github.com
RajivAngoelal
Dear JelteDeJong,
Yes i have seen the post, but the post had nothing to do with my preferred request.
i would like to create a sketch on a particular face. The name of the face does not matter.
JelteDeJong
I cant test this for you but you could try the following.
Dim oFace As Face
if (iLogicVb.Automation.NameExists("face0"))
	iLogicVb.Automation.FindEntity("face0")
else
end if
'add a sketch
Else
(i got the idea from https://forums.autodesk.com/t5/inventor-customization/where-is-new-feature-face-name-in-inventor-201... )
Jelte de Jong
RajivAngoelal
Thank you very much. it works :).
i made the code a little bit smaller
On Error Resume Next
oDoc = ThisApplication.ActiveDocument
oDef = oDoc.ComponentDefinition
Dim partDoc As PartDocument = ThisDoc.Document
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(partDoc)
Dim oFace As Face
oFace = namedEntities.FindEntity("Face0")
oSketch = oDef.Sketches.Add(oFace)
oSketch.name = "Face0"
sam
Dim oFace As Face
else
end if
'add a sketch
Else
this might be dumb question but I am trying to use this as iLogic rule and it gives errors:
Error on Line 4 : 'NameExists' is not a member of 'Autodesk.iLogic.Interfaces.IiLogicAutomation'.
Error on Line 5 : 'FindEntity' is not a member of 'Autodesk.iLogic.Interfaces.IiLogicAutomation'.
Can you please explain why is this error coming up? is the rule meant to be used only in VBA or VB.NET?
Best regards,
Sam
sam
Dim oFace As Face
This is working brilliantly as I thought. Thank you so much.
