Create a sketch in the view, how to set the lines in the sketch to a custom layer
ss13953642009
ss13953642009
For SketchLine type sketch lines, after setting the layer name of the line (SketchLine.Layer.Name == 'Center Line'), it is displayed in the sketch as: By Standard (Center Line). How can I use my custom 'Center Line' layer instead of 'By Standard (Center Line)' when setting the layer?
daltonNYAW9
You can change the default layer in a drawing's styles editor:
Heres how you could change the layers in a sketch programmatically
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oLayer As Layer = oDDoc.StylesManager.Layers.Item("Centerline copy")
Dim oSketch As DrawingSketch = oDDoc.ActiveSheet.Sketches(1)
oSketch.Edit
For Each oSketchEntity As SketchEntity In oSketch.SketchEntities
	oSketchEntity.Layer = oLayer
Next
oSketch.ExitEdit
