Create a simple hole with a specific depth
Hi All
 I ‘m trying to create  a simple hole  by adding the depth, and it throws  the  next exception.
$exception         {"El parámetro no es correcto. (Excepción de HRESULT: 0x80070057 (E_INVALIDARG))"}                System.ArgumentException}
Does anyone know what the error is in the parameter?
hole2 = oComDef.Features.HoleFeatures.AddDrilledByDistanceExtent(oHoleCenters2, "8 mm", "10 mm", PartFeatureExtentDirectionEnum.kNegativeExtentDirection, True, "118 deg")
Public Sub createSimpleHole()
        Dim hole2 As HoleFeature
        Dim oPoint, oPoint2 As Point2d
        oPoint = oTransGeom.CreatePoint2d(1, 1)
        oPoint2 = oTransGeom.CreatePoint2d(1, 1)
       Dim point, point2 As SketchPoint
        point = oSketch.SketchPoints.Add(oPoint, True)
        point2 = oSketch.SketchPoints.Add(oPoint2, True)
        point.HoleCenter = True
        point2.HoleCenter = True
        Dim offset, o2 As TwoPointDistanceDimConstraint
        offset = oSketch.DimensionConstraints.AddTwoPointDistance(lineWidth.StartSketchPoint, point, DimensionOrientationEnum.kVerticalDim, oTransGeom.CreatePoint2d(2, 2), False)
        o2 = oSketch.DimensionConstraints.AddTwoPointDistance(lineHight.StartSketchPoint, point, DimensionOrientationEnum.kHorizontalDim, oTransGeom.CreatePoint2d(-2, 0), False)
        offset.Parameter.Value = (offsetWidth / 10)
        o2.Parameter.Value = Math.Abs(15 / 10)
        Dim d1, d2, d3, d4 As TwoPointDistanceDimConstraint
        d1 = oSketch.DimensionConstraints.AddTwoPointDistance(lineWidth.StartSketchPoint, point2, DimensionOrientationEnum.kVerticalDim, oTransGeom.CreatePoint2d(2, 2), False)
        d2 = oSketch.DimensionConstraints.AddTwoPointDistance(lineHight.StartSketchPoint, point2, DimensionOrientationEnum.kHorizontalDim, oTransGeom.CreatePoint2d(-2, 0), False)
        d1.Parameter.Value = (offsetWidth / 10)
        d2.Parameter.Value = Math.Abs(30 / 10)
        oSketch.ExitEdit()
        Dim oHoleCenters2 As ObjectCollection
        oHoleCenters2 = m_invApp.TransientObjects.CreateObjectCollection
        oHoleCenters2.Add(point)
        oHoleCenters2.Add(point2)
    End Sub
program goalprogram goalprogram goalprogram goal
t_remal
I don't see an error in your code (other than you probably wanted to pass False to AddDrilledByDistanceExtent, because otherwise the last parameter will not be used, but that should not throw an exception).
Could you please share the dataset (with the information what "lineWidth" and "lineHight" are)?
Lubomir
Hi.
Thanks,  I appreciate your comments.
I detected the problem, I has passed   to the parameter an incorrect object, Linewidth and lineHeight are a sketchlines that the user selects.
