Create a new work plane on an angle from reference - iLogic or Macro
Hi .
I would like to know if it is possible to create a new work plane with iLogic. New work plane would be on an angle withe reference to origin axis and plane.
i found this example that call for offset from one of the planes --> https://forums.autodesk.com/t5/inventor-forum/create-a-new-work-plane-with-ilogic/m-p/5385259#M52729...
Is it possible to create what i need with iLogic?
Also, since i am new to Inventor and iLogic (and can't code), where can i find good examples so i can learn?
Thank you in advance and i apologize for the open ended question.
EDIT: I just found out a WorkPlanes.AddByLinePlaneAndAngle.. hopefully that is what i need.
i Was able to work it out on my own.. Creates a 45 deg angle based on Y axis and XY plane references (which can be tailored to our needs)
oDef = ThisDoc.Document.ComponentDefinition
Dim oWPlane As WorkPlane
Dim oAxis As WorkAxes
oAxis= oDef.WorkAxes
oWPlane = oDef.WorkPlanes.AddByLinePlaneAndAngle(oAxis("Y Axis"), oDef.WorkPlanes("XY Plane"), 45)
oWPlane.Name = "Plane_Name"
