Create a Inventor environment folder
Is it possible to create an iLogic rule that allows you to create a folder and several pads with predefined names?
JelteDeJong
are you looking for something like this?
' define path where environments are created
Dim mainPath As String = "D:\forum"
' definf sube folder name
Dim subFolder As String = "sub folder"
' ask the name of for a folder name
Dim result As String = InputBox("environment folder name", "environment", "name here")
' cretae strings with the paths to create
Dim environmentPath As String = IO.Path.Combine(mainPath, result)
Dim subPath As String = IO.Path.Combine(environmentPath, subFolder)
' create the paths on drive
IO.Directory.CreateDirectory(environmentPath)
IO.Directory.CreateDirectory(subPath)
' open the main folder
Process.Start(environmentPath)
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you. It helped me understand how it works. I adjusted it a little. Do I need to know how to do to me vytviřílo more subdirectories.
Dim mainPath As String = ThisDoc.Path
Dim result As String = "Data CNC"
Dim subFolder As String = "Sheets"
Dim subFolder As String = "Plastics"
Dim subFolder As String = "MDV"
' cretae strings with the paths to create, vytvoří řetězce s cestami k vytvoření Dim environmentPath As String = IO.Path.Combine(mainPath, result) Dim subPath As String = IO.Path.Combine(environmentPath, subFolder) ' create the paths on drive, vytvořtí cesty na jednotce IO.Directory.CreateDirectory(environmentPath) IO.Directory.CreateDirectory(subPath) ' open the main folder, otevře hlavní složku Process.Start(environmentPath)
JelteDeJong
What do you think of this?
' create environment folder
Dim environmentPath As String = IO.Path.Combine(mainPath, "Data CNC")
' definf subfolder name
Dim subFolders As List(Of String) = New List(Of String)()
subFolders.Add("Sheets")
subFolders.Add("Plastics")
subFolders.Add("MDV")
' create sub folders
For Each subFolder As String In subFolders
Next
Jelte de Jong
Thanks. You helped me a lot. I was thinking about it a little bit and I thought of that. But yours is easier.
Dim subFolder1 As String = "plechy"
Dim subFolder2 As String = "plasty"
Dim subPath1 As String = IO.Path.Combine(environmentPath, subFolder1)
Dim subPath2 As String = IO.Path.Combine(environmentPath, subFolder2)
IO.Directory.CreateDirectory(subPath1)
IO.Directory.CreateDirectory(subPath2)
