Counting tapped holes
Message 1 of 8
Hello guys,
I have a question about tapped holes. I want to count all tapped holes in a part using iLogic. I'm currently working on a rule that does this and the rule already counts tapped holes and also cuts/extrusions with a thread in them. This is the rule.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oHole As HoleFeature
Dim oHoles As HoleFeatures = oDef.Features.HoleFeatures
Dim oThreadFeatures As ThreadFeatures
	oThreadFeatures = oDef.Features.ThreadFeatures
Dim oThreadFeature As ThreadFeature
Dim oThreadInfo As ThreadInfo
'Er zit verschil tussen tapped holes die met de hole functie zijn aangebracht en gaten waar een thread in is aangebracht.
'Deze worden afzonderlijk van elkaar bepaald en bij elkaar opgeteld.
MessageBox.Show(oThreadFeatures.Count, "Aantal threadfeatures")
For Each oHole In oDef.Features.HoleFeatures
If oHole.Tapped = True Then
i=i+1
Next
MessageBox.Show(i, "aantal tapgaten")
TapgatenTotaal=oThreadFeatures.Count + i
MessageBox.Show(TapgatenTotaal, "Totaal aantal tapgaten")
But the holes that are being counted, are all individual holes. When a tapped hole is in a pattern, the rule will count only one hole, the one that is in the model tree above the pattern. I found the rule that is below on the forum to count all holes in a pattern. I tried to modify this rule so it would only count patterns with a tapped hole as parent feature but I couldn't get it to work. I tried the following.
If Not (TypeOf oRP.ParentFeatures.Item(1) Is HoleFeature.Tapped) Then Continue For
But this didn't work. I also tried to put all the tapped holes that are recognized in the first rule in a object collection and the run the pattern rule for each hole in the collection but that didn't work either. The rule fills in all the holes that are in the collection in every available pattern so the outcome is way to high.
Does anyone know how I can modify the rule (or make a new one) so it only counts tapped holes?
'assume rectangular pattern
Dim oRectPatterns As RectangularPatternFeatures = oDef.Features.RectangularPatternFeatures
Dim N As Integer = 0 'counter
For Each oRP  As RectangularPatternFeature In oRectPatterns
	'consider only hole patterns
    If Not (TypeOf oRP.ParentFeatures.Item(1) Is HoleFeature) Then Continue For
	For Each oFPE  As FeaturePatternElement In oRP.PatternElements
		If Not oFPE.Suppressed Then N += 1
	Next
Next
'assume circular pattern
Dim oCircPatterns As CircularPatternFeatures = oDef.Features.CircularPatternFeatures
For Each oCP  As CircularPatternFeature In oCircPatterns
    If Not (TypeOf oCP.ParentFeatures.Item(1) Is HoleFeature) Then Continue For
	For Each oFPE  As FeaturePatternElement In oCP.PatternElements
	Next
Next
MsgBox ("The number of holes in the current part is:  " & N)
Eric
Replies (7)
Message 2 of 8
j.romo
Im having the same problem.
I found a code about a year ago, cant remember who posted it. but it counts rectangular patterns
I would like a Rule to count them ALL.
right now I trigger the single feature rule to count holes as the one you havve and then trigger the following rule
SyntaxEditor Code Snippet
' Calc Holes in HoleFeature Pattern
'assume part document
Dim oDoc As PartDocument = ThisDoc.Document
'Set oDoc = ThisApplication.ActiveDocument
	Next
Next
 Hope someone could share the code for circular pattern feature count
or a rule to count hem all.
thanks
Message 3 of 8
dgreatice
try This, I'm using iLogic:
Sub Main
Dim oApp As Application
Dim oPD As PartDocument
Dim oPCD As PartComponentDefinition
Dim oFeats As PartFeatures
Dim oRecPat As RectangularPatternFeature
Dim oCirPat As CircularPatternFeature
Dim oParentFeat As PartFeature
Dim oHoleInPat As HoleFeature
Dim oCheckHole As HoleFeature
Dim ObjCol1 As ObjectCollection
oApp = ThisApplication
oPD = oApp.ActiveDocument
oPCD = oPD.ComponentDefinition
oFeats = oPCD.Features
ObjCol1 = oApp.TransientObjects.CreateObjectCollection
For Each oRecPat In oFeats.RectangularPatternFeatures
	oParentFeat = oRecPat.ParentFeatures.Item(1)
	If oParentFeat.Type = ObjectTypeEnum.kHoleFeatureObject Then
		oHoleInPat = oParentFeat
		If oHoleInPat.Tapped = True Then
			Call ObjCol1.Add(oRecPat)
Next
For Each oCirPat In oFeats.CircularPatternFeatures
	oParentFeat = oCirPat.ParentFeatures.Item(1)
			Call ObjCol1.Add(oCirPat)
Next
For Each oHole In oFeats.HoleFeatures
		Call ObjCol1.Add(oHole)
Next
Dim CountHole As Double
Call GetCount(ObjCol1, CountHole)
MsgBox (CountHole)
End Sub
Sub GetCount(ByVal ObjCol1 As ObjectCollection, ByRef CountHole As Double)
For i = 1 To ObjCol1.Count
	On Error Resume Next
	If ObjCol1.Item(i).Type = ObjectTypeEnum.kHoleFeatureObject Then
		For Each itemrec In ObjCol1
			If itemrec.Type = ObjectTypeEnum.kRectangularPatternFeatureObject Or itemrec.Type = ObjectTypeEnum.kCircularPatternFeatureObject Then
				If ObjCol1.Item(i).Name = itemrec.ParentFeatures.Item(1).Name Then
					Call ObjCol1.Remove(i)
		Next
Next
CountHole = 0
For Each Item In ObjCol1
	If Item.Type = ObjectTypeEnum.kRectangularPatternFeatureObject Or Item.Type = ObjectTypeEnum.kCircularPatternFeatureObject Then
		CountHole = CountHole + Item.PatternElements.Count
		ElseIf Item.Type = ObjectTypeEnum.kHoleFeatureObject Then
		CountHole = CountHole + 1
Next
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 8
BrianEkins
There's another approach that doesn't depend on the feature information. Using features for threads has a few problems, many of which you've noted but there are others too. Take a look at this post for not info about the other solution.
https://ekinssolutions.com/getting-thread-information-in-inventor-and-apprentice
Brian Ekins
Message 5 of 8
j.romo
Wow
worked like a charm
I had other aprroach searching circular patterns also
but this weorks better
thanks a lot
Message 6 of 8
dgreatice
This Case are Close?
Message 7 of 8
Hi dgreatice,
I have a question about this hole counting code. I cannot run it on this particular part, it returns 0 for some reason. (See screenshot below). However, do you think this code can accurately count the holes in a pattern that is made of two different holes?
The pattern below is made up of two different types of holes. One is .25in diameter and the other is .75in diameter. To create the pattern I selected Hole1 and Hole2 as the features to pattern. Then I patterned them 3 times. The number of elements in this pattern is 3, but the number of holes is 6. I am guessing that your code would output 3 holes?
Message 8 of 8
dgreatice
because this topic about tapped holes, I just collect tapped holes only, so if you want get normal holes, and in 1 Feature pattern there are 2 parentFeature, you must iterate again, and add separate each type of holes.
example: This only have 1 parentFeature (Hole 1) and type hole are tapped.
else
'more code for normal holes End If End If Next
