Counter for Virtual Components - Help
munderwood4GRE6
munderwood4GRE6
I'm trying to write a counter that will go through each occurrence/part in an assembly and count how many of those type of occurrences/parts there are based off the occurrences part # iProperty.
I'm struggling with how to name the counter because I need it to be triggered by the part # iProperty.
For example, if I had 3 screws and 5 nails I would need a counter to hold 3 and one to hold 5 and have a way to assign the counters name based off the occurnences part # iProperty so I can pass that into an iLogic generated VC.
Any help would be greatly appreciated.
WCrihfield
Hi @munderwood4GRE6.  Your request is a little difficult to understand.  What are you calling a 'virtual component'?  There is a VirtualComponentDefinition that is only found within an assembly's BOM.  I believe that is the type of ComponentDefinition that is returned from a BOM row that was created using the 'Create Virtual Component' tool within the BOM dialog.  Is that what you mean?  Or is the component's BOMStructure set to something like Reference or Phantom or Purchased?  Also, it seems to me like you would need a collection type variable with two factor items inside as a variable to use in the code, to return both a count and part number data of multiple different possible components.  Maybe something like a NameValueMap or Dictionary would work in a situation like that.  With a variable like that, you can have a collection object to gather data into, and each item in that collection can hold 2 pieces of data...like a Part Number and an Integer.
Wesley Crihfield
(Not an Autodesk Employee)
munderwood4GRE6
It may be easier for me to add the rule that I have so far:
'Delete All Virtual Components
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim asmOcc As ComponentOccurrence
For Each asmOcc In oAsmCompDef.Occurrences
If TypeOf asmOcc.Definition Is VirtualComponentDefinition Then
asmOcc.Delete
Next
'Look for all the Parts that have the Custom Virtual Component iProperty added to them
For Each oOccurrence In oAsmCompDef.Occurrences
Try
iProperties.Value(oOccurrence.Name, "Custom", "VC") = "True"
Try
iProperties.Value(oOccurrence.Name, "Custom", "VC1")= "VC1"
VC1_NAME = iProperties.Value(oOccurrence.Name, "Custom", "VC1_NAME")
VC1_PNUM = iProperties.Value(oOccurrence.Name, "Custom", "VC1_PNUM")
VC1_DESC = iProperties.Value(oOccurrence.Name, "Custom", "VC1_DESC")
VC1_BOMP = iProperties.Value(oOccurrence.Name, "Custom", "VC1_BOMP")
VC1_BCLASS = iProperties.Value(oOccurrence.Name, "Custom", "VC1_BCLASS")
'Create a virtual component
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Dim oNewOcc As ComponentOccurrence
oNewOcc = oAsmCompDef.Occurrences.AddVirtual(VC1_NAME, oMatrix)
Dim oCVirtualCompDef As VirtualComponentDefinition
oCVirtualCompDef = oNewOcc.Definition
InventorVb.DocumentUpdate()
'Pass in the Virtual Component iProperties from the part to the Virtual Component
iProperties.Value(VC1_NAME & ":1", "Project", "Part Number") = VC1_PNUM
iProperties.Value(VC1_NAME & ":1", "Project", "Description") = VC1_DESC
iProperties.Value(VC1_NAME & ":1", "Custom", "BOM Priority") = VC1_BOMP
iProperties.Value(VC1_NAME & ":1", "Custom", "BOM Class") = VC1_BCLASS
Catch EE As Exception
End Try
'Run the code again for a second VC embedded in the part, plan to add the ability to check for 5
Try
iProperties.Value(oOccurrence.Name, "Custom", "VC2")= "VC2"
VC2_NAME = iProperties.Value(oOccurrence.Name, "Custom", "VC2_NAME")
VC2_PNUM = iProperties.Value(oOccurrence.Name, "Custom", "VC2_PNUM")
VC2_DESC = iProperties.Value(oOccurrence.Name, "Custom", "VC2_DESC")
VC2_BOMP = iProperties.Value(oOccurrence.Name, "Custom", "VC2_BOMP")
VC2_BCLASS = iProperties.Value(oOccurrence.Name, "Custom", "VC2_BCLASS")
oNewOcc = oAsmCompDef.Occurrences.AddVirtual(VC2_NAME, oMatrix)
iProperties.Value(VC2_NAME & ":1", "Project", "Part Number") = VC2_PNUM
iProperties.Value(VC2_NAME & ":1", "Project", "Description") = VC2_DESC
iProperties.Value(VC2_NAME & ":1", "Custom", "BOM Priority") = VC2_BOMP
iProperties.Value(VC2_NAME & ":1", "Custom", "BOM Class") = VC2_BCLASS
End Try
End Try
Next
munderwood4GRE6
This is working great for generating one virtual component in the assembly for the parts that have the iProperties added that trigger them. The issue I'm having is coming up with a way to count them up and then override the BOM with the counted qty
JelteDeJong
Maybe this does help you.
Public Class ThisRule
    Sub Main()
        Dim doc As AssemblyDocument = ThisDoc.Document
        Dim virComps = findAllWhere(doc,
            Function(occ) occ.Definition.Type = ObjectTypeEnum.kVirtualComponentDefinitionObject).
            ToList()
        Dim counter As New Dictionary(Of String, Double)
        For Each occ As ComponentOccurrence In virComps
            Dim def As VirtualComponentDefinition = occ.Definition
            Dim iProperty As [Property] = def.PropertySets.
                Item("Design Tracking Properties").
                Item("Part Number")
            Dim key As String = iProperty.Value
            Dim val As Double = def.BOMQuantity.GetEvaluatedBaseQuantity(def.BOMQuantity.UnitQuantity)
            If (counter.ContainsKey(key)) Then
                counter.Item(key) = counter.Item(key) + val
            Else
                counter.Add(key, val)
        Next
        Dim msg As String = ""
        For Each item In counter
            msg = msg & item.Key & " : " & item.Value & System.Environment.NewLine
        Next
        MsgBox(msg)
    End Sub
    Private Function findAllWhere(doc As AssemblyDocument,
                predicate As Func(Of ComponentOccurrence, Boolean)) As IEnumerable(Of ComponentOccurrence)
        Dim list As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
            Occurrences.Cast(Of ComponentOccurrence).
            Where(predicate)
        Dim assemblyList As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
            Where(Function(o) o.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject)
        For Each assOcc As ComponentOccurrence In assemblyList
            If TypeOf assOcc.Definition Is VirtualComponentDefinition Then Continue For
            Dim assDoc As AssemblyDocument = assOcc.ReferencedDocumentDescriptor.ReferencedDocument
            Dim listToAdd As IEnumerable(Of ComponentOccurrence) = findAllWhere(assDoc, predicate)
            list = list.Concat(listToAdd)
        Next
        Return list
    End Function
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
munderwood4GRE6
Is there a simpler method? iLogic and programming are not my strong suite and I don't understand the code that you've shared.
JelteDeJong
depending on your exact need maybe there is a simpler method. but I can start by explaining what happens. you will comment in the code.
' this function finds all VirtualComponent and puts them in a list.
' you can find more about this function on my blog:
' http://www.hjalte.nl/34-universal-occurrence-search-function
    ToList()
' create a Dictionary of key/value pairs
' Loop over all VirtualComponents
    ' Get the iProperty
        Item("Part Number")
    ' Check ik the counter with sertain key already
    ' exists in the Dictionary of key/value pairs.
        ' Yes: add the value of the found VirtualComponent to the item we found before
    Else
        ' No: create create a key/value pair and add it to the Dictionary
Next
' This is just to show how you can use the information in the Dictionary
Next
MsgBox(msg)
Jelte de Jong
