Count for All Referenced Documents
shastu
Advisor Advisor
shastu
Is there a way to get a count for all the Referenced Documents before it goes into the "For Each" loop?
For example:
Sub FileRefs()
   Dim oAsmDoc As AssemblyDocument
   Set oAsmDoc = ThisApplication.ActiveDocument
   Dim oAsmCompDef As AssemblyComponentDefinition
   Set oAsmCompDef = oAsmDoc.ComponentDefinition
   Dim oOcc As ComponentOccurrence
   Dim oRefDoc As Document
    'MsgBox oRefDoc.Count
   For Each oRefDoc In oAsmDoc.AllReferencedDocuments
       MsgBox oRefDoc.DisplayName
    Next
End Sub
I want to know how many times it is going to go through the For Each loop before I enter into it.  See where the 'MsgBox oRefDoc.Count is?  That is where I need to know.  If I have an assembly with three parts the count should be zero.  If I have a structure and I am interested in the Count for the 123.iam how would I do that in the following Structure:
Assy.iam
     Part1.ipt
     Part2.ipt
     123.iam
          Part3.ipt
          Part4.ipt
     Part5.ipt
So the count for 123.iam would be 3.  One for the 123.iam, Part3.ipt, and Part4.ipt
Hopefully that makes sense.
Owner2229
Hi, I can't tell right from the top of my head, but it will be one of these:
oAsmDoc.AllReferencedDocuments.Count
Or:
oAsmDoc.AllReferencedDocuments.Items.Count
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
shastu
Thanks for the response.  The oAsmDoc.AllReferencedDocuments.Count will give me the total.  I was hoping there was a way that I could get a count for each time it goes to the next level.  In the example given, the number for the oAsmDoc.AllReferencedDocuments.Count would be 6, but what I need is a way to check the count for each level so it would be like this:
1
1
3
1
So based off your suggestion I tried this:
oRefDoc.AllReferencedDocuments.Count
and that worked.  Thanks for pointing me in the right direction.
Owner2229
Alright then, here it is:
Sub FileRefs()
   For Each oRefDoc In oAsmDoc.ReferencedDocuments
       Dim oCount As Integer
       oCount = oRefDoc.AllReferencedDocuments.Count + 1
       MsgBox oCount
   Next
End Sub
Mike
