Could you help me to find bug from rule my assigning part number
ssiem
Message 1 of 1
ssiem
Hello
I have rule assigning part number based on BOM stucture
This is
Option Explicit On
Class ThisRule
	Dim As_count As Integer = 0
	Dim Pr_count As Integer = 0
	Dim Wl_count As Integer = 0
	Dim St_count As Integer = 0
	Dim Pt_count As Integer = 0
	Dim Rf_count As Integer = 0
	Sub Main
		ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
		Dim oADoc As AssemblyDocument = ThisDoc.Document
		Dim oBOM As BOM = oADoc.ComponentDefinition.BOM
		Dim oModelBOMView As BOMView = oBOM.BOMViews.Item(1)
		'BOM Export 후 xml파일과 아래 경로를 일치할것
		oBOM.ImportBOMCustomization("D:\STCRECH.xml")
		oBOM.StructuredViewEnabled = True
		oBOM.StructuredViewFirstLevelOnly = False
		oBOM.SetPartNumberMergeSettings(False)
		Dim oBOMView As BOMView = oBOM.BOMViews.Item("구조적")
		oBOMView.Sort("질량", False, "체적", False)
		oBOMView.Renumber()
		oBOMView.Sort("Part Number", True)
		oBOMView.Renumber()
	End Sub
	Private Sub WritePartMumb(ByVal oBOMRows As BOMRowsEnumerator)
		For Each oRow As BOMRow In oBOMRows
			If Not IsStandardContentCenterRow(oRow) Then
				Dim partnumber As String = PartNumberGenerator(oRow)
				If partnumber <> "" Then
					oRow.ComponentDefinitions(1).Document.PropertySets(3)(2).Value = partnumber
			If oRow.ChildRows IsNot Nothing Then
				WritePartMumb(oRow.ChildRows)
		Next
	End Sub
	Private Function PartNumberGenerator(ByVal oRow As BOMRow) As String
		Select Case oRow.BOMStructure
			Case BOMStructureEnum.kNormalBOMStructure
				Dim rowDocType = GetDocumentType(oRow)
				If rowDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
					As_count = As_count + 1
					Return "As-" & As_count.ToString("000")
				ElseIf rowDocType = DocumentTypeEnum.kPartDocumentObject Then
					Pr_count = Pr_count + 1
					Return "Pr-" & Pr_count.ToString("000")
				Else
					Return ""
			Case BOMStructureEnum.kInseparableBOMStructure
				Wl_count = Wl_count + 1
				Return "Wl-" & Wl_count.ToString("000")
			Case BOMStructureEnum.kPurchasedBOMStructure
				St_count = St_count + 1
				Return "St-" & St_count.ToString("000")
			Case BOMStructureEnum.kPhantomBOMStructure
				Pt_count = Pt_count + 1
				Return "Pt-" & Pt_count.ToString("000")
			Case BOMStructureEnum.kReferenceBOMStructure
				Rf_count = Rf_count + 1
				Return "Rf-" & Rf_count.ToString("000")
		End Select
		Return "" ' default case if we can't get a part number
	End Function
	Private Function IsStandardContentCenterRow(ByVal oRow As BOMRow) As Boolean
		For Each compDef As ComponentDefinition In oRow.ComponentDefinitions
			Dim partCompDef As PartComponentDefinition = TryCast(compDef, PartComponentDefinition)
			If partCompDef IsNot Nothing AndAlso partCompDef.IsContentMember Then
				Return True
		Next
		Return False
	End Function
	Private Function GetDocumentType(ByVal oRow As BOMRow) As DocumentTypeEnum
			If partCompDef IsNot Nothing Then
				Return DocumentTypeEnum.kPartDocumentObject
			Dim assemCompDef As AssemblyComponentDefinition = TryCast(compDef, AssemblyComponentDefinition)
			If assemCompDef IsNot Nothing Then
				Return DocumentTypeEnum.kAssemblyDocumentObject
		Next
		Return DocumentTypeEnum.kUnknownDocumentObject
	End Function
End Class
Basic structure is '00-000'
it start from Assemblydocument
Following BOM in inventor
Rule for prefix
Normal - two type (As for assembly, Pr for part)
Inseparable - Wl
Purchased - St
Phantom - Pt
Reference - Rf
(Standard product is exception,No changing Part number)
Rule for suffix
001
002
003
004...
this sequence is ascending order of mass
as a exception if it has same mass by missing selecting material or something, ascending order of volume is okay
it should be different according to the prefix
for example Part number
As-001 (assembly and first heavy one)
As-002(assembly and second heavy one)
Pr-001(Part and first heavy one)
Pr-002(Part and second heavy one)
Wl-001(Welding and first heavy one)
But it ignore sequence when i play rule
For example I sort it by part number is show some of part number is ignored
it should be start from 001 per each of prefix
could you help me?
Replies (0)
