Could not change a part multi-value parameter from Assembly using ilogic
   greetings, can anyone help me around with the code i am using in inventor to change the repeated Parts Multivalue text parameter from the assembly level (Eg. to change value "OFF" for a feature appearance, where  the same part is used  in different names in an assembly (500 times) so, what am i trying is not to open individually the parts i am trying to run the code which shown below (and the CODE IS VERY GOOD FOR THE METRIC VALUE CHANGE BUT ONCE IT IS A MULTIVALUE THE CODE IS NOT WORKING ITS RUNNING BIT NO CHANGES HAPPENING)...Will be a great help if any one helps me in changing this multivalue parameter..
Note:
i) i cannot get the 500 parts repeated file name list, but the existing code works fine for metric values with variable part file names in the assembly (see text or multi values needs some alteration).
Attaching a part file image/ Assembly little one for reference
Below the used code:
SyntaxEditor Code Snippet
' set a reference to the assembly component definintion.' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
Parameter.Quiet = True
Parameter(oOccurrence.Name, "CABLE_TRAY_VISI") = "OFF"
Else
Next
Thanks will be great help if the up code is made feasible for  text too....
Thanks & Regards,
Suresh.RM
+91 87544 03310
HermJan.Otterman
hello,
try
Parameter(Occurence.displayname, "CABLE_TRY_VISI") = "Off"
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Hi Herm jan
        Thank you for your support and reply, my older code itself changing the value inside the parameter (Attached the image refers the same) but today only i found out that the assembly is not updating if i open the rule and close in individual file it automatically makes the components to suppress as written in the rule.
But here i am not even changing any thing manually it just needs an update control to be run so the each segments responds to the inbuilt rule and make the cable tray hide or suppress...
Can you help me around i didn't use the the string you gave.....
Thanks & Regards,
Suresh.RM
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that below iLogic code would help. After updating MultiValue parameter, use "iLogicVb.UpdateWhenDone = True" to update parameter. Are
Else End If Next
On the other hand, "Component.IsActive(Occurrence.Name) = False" can be used to hide parts.
Component.IsActive(oOccurrence.Name) = False
Else
Next
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
