corner seam
corner seam
corner seam
Can somebody tell me if i can control the Maximum Gap Distance and Face/Edge Distance in the Corner Seam by iLogic.
I want to change between those two in different styles.
Something like this?
If currentStyle = "Kemi_0.6" Then
   Face/Edge Distance = treu
   Parameter("overlap") = 0.8 ul
see also my  topic:http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/control-Corner-Seam/td-p/3727484
xiaodong_liang
Autodesk Support
Autodesk Support
please do not mind I jump into your question again. As suggested in the other post, you could use Inventor API to access CornerDefinition in which the properties/settings are available. such as CornerDefinition.CornerDefinitionType. I attached a snapshot of the API help reference.
where can i find the api reference, i work with inventor 2013.
Is it a help file i can find in Inventor?
xiaodong_liang
Autodesk Support
Autodesk Support
you can find it at
C:\Program Files\Autodesk\Inventor 2013\Local Help\admapi_17_0.chm
Thanks, i will look into it.
