CopyTo Drawing View Object issues
I am trying to create a VBA code to automate moving Drawing Views to another sheet.  I am looping through a collection in a selection set and picking out the drawing view objects.  It works fine until a Leader Note is inside the drawing view then it fails.  So I created a filter to filter out the Leader Notes and it works great if the leader extends outside the Drawing View but when it is in the drawing view it fails.  What are my options?
I catch the the Drawing view with
If itm.Type = kDrawingViewObject Then 'or 117441536
     Call itm.CopyTo(DestSheet)
I catch the leaders that go outside the Drawing view with
If SelCol(counter).Type = kLeaderNoteObject Then 'or 117473024
    For X = 1 To SelCol(counter).Leader.AllNodes.Count
        oObjCol.Add SelCol(counter).Leader.AllNodes(X).Position
    Next
    Set NLN = DestSheet.DrawingNotes.LeaderNotes.Add(oObjCol, SelCol(counter).FormattedText, SelCol(counter).DimensionStyle)
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
For further investigation, can you please provide sample drawing and source code?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I am sorry been away from desk.
I figured out I was capturing the selection inefficiently.  If I use the below code it works great.
    Dim SelCol As ObjectCollection
    Set SelCol = ThisApplication.TransientObjects.CreateObjectCollection
    Dim obj As Variant
    For Each obj In oDoc.SelectSet
        SelCol.Add obj
    Next
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
That's nice to hear that you figured out a solution.
Please feel free to contact if you need any help further.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
