Copy Sketch Symbol in a view
I have a code that will place a sketch symbol on a view. The problem I have is some times that symbol is used in that same view multiple times Is there a line of code I can put in my code so the symbol  places in the view  a specified number of time based on the a message box enters?
A.Acheson
That should be possible, can you post the code your using? You really just need to use a for loop where the add line is . Rough logic below.
Dim oCount As Integer
oCount = InputBox("Enter Number Here", "Symbol Qty", "1")
Dim i As Integer
For i = 1 To oCount
	'add symbol and position move.
	MessageBox.Show(i, "Title")
Next
Regards
Alan
