Copy sketch (including hatch) as-is into a new sketch using Inventor C# API
manasi_patilESZTV
manasi_patilESZTV
Hi Everyone,
As shown in the attached image, I have a sketch in Inventor that contains  a hatch pattern , Centerlines, Center Mark and geometry.
My requirement:
I want to copy this entire sketch exactly as it is (geometry + hatch+ Centerlines + Center Mark) into a new sketch programmatically using the Inventor C# API.
So far, I found:
  • I can loop through SketchEntities and recreate lines/arcs in the new sketch, but this doesn’t bring the hatch.
  • Hatch regions (SketchHatchRegion) don’t seem to provide a direct method to copy or duplicate into another sketch.
  • There doesn’t appear to be a direct “copy-paste” equivalent in the API.
Question:
  • Is there any way to directly copy a sketch (with hatch intact) into a new sketch using the API?
Any examples or workarounds would be highly appreciated.
Thanks!
marcin_otręba
What do you want to accomplish exacly ?
I see that we talk about sketch in drawing enviroment ? could you use sketched symbol functionality instead ?
I dont think it is possible to copy it all to new sketch but to iterate trough drawing hatches use SketchHatchRegions:
you can use it to check imputują and regenerate it in new sketch
Inventor 2025 Help | DrawingSketch Object | Autodesk
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
