Copy Revision table contents to Custom Table
f_calebh
Message 1 of 11
f_calebh
I'm trying to create a work around for retaining legacy revision rows before populating with Vault Data. (populating old legacy revision tables with Vault Data deletes legacy revision rows)
I have iLogic Code to:  export revision tables out, and even Import them back in as a Custom Table, but I was wondering if there was Code that would instead just put the Revision table contents into a Custom Table without exporting?
I guess the first question should be, is this doable?
Replies (10)
Message 2 of 11
WCrihfield
I have a code started for you, but it still has a bug (or few), so it still needs a little more work.  But, I'm headed home for the weekend, so I'm just going to post what I have so far.  I hope this helps.  Have a great weekend. 🙂
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("A Drawing Document must be active for this rule (" & iLogicVb.RuleName & ") to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
	Exit Sub
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim oRevTbl As RevisionTable = oSheet.RevisionTables.Item(1)
Dim oTitle As String = oRevTbl.Title
Dim oPos As Point2d = oRevTbl.Position
Dim oRowCount As Integer = oRevTbl.RevisionTableRows.Count
Dim oColCount As Integer = oRevTbl.RevisionTableColumns.Count
Dim oCellCount As Integer = oRowCount * oColCount
Dim oColTitles(oColCount - 1) As String
Dim oColWidths(oColCount - 1) As Double
Dim oRowHeights(oRowCount-1) As Double
Dim oCellContents(oCellCount) As String
Dim oRow, oCol, oCell As Integer
oCell = 0
For oRow = 1 To oRowCount
	For oCol = 1 To oColCount
		For oCell = 1 To oCellCount - 1
			oCellContents(oCell) = oRevTbl.RevisionTableRows.Item(oRow).Item(oCol).FormattedText
			If oCell < (oCellCount - 1) Then oCell = oCell + 1
		Next
		oColTitles(oCol - 1) = oRevTbl.RevisionTableColumns.Item(oCol).Title
		oColWidths(oCol - 1) = oRevTbl.RevisionTableColumns.Item(oCol).Width
		If oCol < oColCount Then oCol = oCol + 1
	Next
	oRowHeights(oRow-1) = oRevTbl.RevisionTableRows.Item(oRow).Height
	If oRow < oRowCount Then oRow = oRow + 1
Next
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oCTable As CustomTable = oSheet.CustomTables.Add(oTitle, oPos, oColCount, oRowCount, oColTitles, oCellContents, oColWidths, oRowHeights)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 11
f_calebh
It looks like that's what I need. I wasn't sure how to approach problem solving the bug message, but the looks very promising.
Hope you enjoy your weekend as well. Thanks!
Message 4 of 11
Ralf_Krieg
Hello
The loop "For oCell = 1 To oCellCount - 1" is not necessary. I've modified your code a little bit and it seems to work now.
    Exit Sub
Dim oRowHeights(oRowCount - 1) As Double
Dim oCellContents(oCellCount-1) As String
		oCell = oCell+1
	Next
	oRowHeights(oRow - 1) = oRevTbl.RevisionTableRows.Item(oRow).Height
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 5 of 11
f_calebh
That was the ticket. You guys have been a great help!  Thanks!
Message 6 of 11
f_calebh
I was thinking about making this run automatically after open.  For that I'd want to identify if my Custom Table already exists so I don't keep pasting over the top of it.
I'm extremely new to ilogic so I may not even be on the right track here, but this is what I came up with.
 It'll recognize a named custom table if it has one, but if it doesn't have one, it'll error out.  If I run just the portion after the the if statement separately, it works.  I'm guessing it has to do with the declarations, but I'm stumped if this can be fixed?  (I made a few other changes to specify the sheet but that I don't think is the issue).  If I'm way off track, no worries, but I thought I would ask.
    Exit Sub
Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDDoc.Sheets(2)
Dim oRevTable As CustomTable
oRevTable = oSheet.CustomTables.Item(1)
If oRevTable.Title = ("REVISION HISTORY - LEGACY") Then
	Exit Sub
Dim oTitle As String = "REVISION HISTORY - LEGACY"
Dim oPos As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(27.0815,27.145)
		oCell = oCell+1
	Next
Next
oCTable = oSheet.CustomTables.Add(oTitle, oPos, oColCount, oRowCount, oColTitles, oCellContents, oColWidths, oRowHeights)
Message 7 of 11
WCrihfield
You can insert this block of code in there right after defining the oSheet variable, to check for a pre-existing custom table.  If it finds it, it will let you know, and ask you if you want to replace the existing one.  If you say 'Yes', it will delete the existing one, then continue with the rest of the code to create a new one.  If you say 'No', it will exit the code.
Dim oExists As Boolean 'false by default
If oSheet.CustomTables.Count > 0 Then
	For Each oCTbl As CustomTable In oSheet.CustomTables
		If oCTbl.Title = "REVISION HISTORY - LEGACY" Then
			oExists = True
			oAns = MsgBox("That Custom Table already exists." & vbCrLf & _
			"Do you want to replace it?", vbYesNo + vbQuestion, "Custom Table Exists")
			If oAns = vbYes Then
				oCTbl.Delete
			ElseIf oAns = vbNo Then
				Exit Sub
	Next
Also, to make this work, change the following line lower in the main code:
To:
(which you already did)
Wesley Crihfield
Message 8 of 11
f_calebh
It looks like if I specify another sheet other than the active sheet, I need to activate that sheet at least once before the code works.  Out of curiosity, would you know why that is?  I can write in the sheet activation in at the beginning and that fixes it, but I found this an odd behavior.
Message 9 of 11
WCrihfield
If you want, we could change the code so that it loops through each sheet in the drawing, checking if each sheet has a revision table in it, and if it does, create a duplicate of that revision table as a custom table, that way it wouldn't matter what sheet you specify in the code.  I believe that which ever sheet the code is going to be placing a new custom table on needs to be 'active' or 'activated', because we're physically placing that new custom table on it at a specific 2d location.  That simple 2d location doesn't know/care which sheet is active, so we have to set that part up as needed before that point in the code.  The Sheet object has a method called 'Activate', that we can use for that purpose as we loop through the sheets.
We could also put the bulk of the code that gathers data from the existing revision table and creates the new custom table into a separate, lower sub routine, then call that sub routine within the loop of the sheets, when it finds an existing revision block.
Wesley Crihfield
Message 10 of 11
f_calebh
This is my fix.  We have what we call a "revision history sheet" on all our drawings and it's always the last sheet, so this is how I handled it:
'Activate All Sheets in Document
For Each oSheet In oDDoc.Sheets
	oSheet.Activate
Next
'set oSheet as the last sheet in a document
oSheet = oDDoc.Sheets(oDDoc.Sheets.Count)
Message 11 of 11
john.hughesFNM
Ive modified this code. Perhaps its useful to someone else?
It will update all rev tables across all sheets.
It will update the rev table style to match the styles library
It will quit if it detects the script has already been run.
Sub Main()
'Check if drawing
	MsgBox("A Drawing Document must be active for this rule (" & iLogicVb.RuleName & ") to work. Exiting.", vbOKOnly + vbCritical, "Don't worry, Rodney. This time next year, we'll be millionaires!")
	Exit Sub
Dim oTitle As String = "LEGACY REVISION HISTORY"
Dim oTable As CustomTable
'Stops the iLogic running if Legacy revision history exists.
		If oCTbl.Title = oTitle Then
	Next
	Exit Sub
'Alternative insertion position off page.
'Dim oPos As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0,0)
Dim oCellContents(oCellCount - 1) As String
'Get Rvision table information
		oCell = oCell + 1
	Next
Next
'Apply to each sheet
	'Remove old revision tables
	If oSheet.RevisionTables.Count > 0 Then
		For Each oRevTable In oSheet.RevisionTables
			oRevTable.Delete
		Next
	'Insert new legacy revision table
	'set the table style to match Legacy Revision Table. You need to create a table style in the styles editor, this can be a global style.
	Dim oActiveTableStyle As TableStyle
	Dim oTableTitle As String
	oActiveTableStyle = oDDoc.StylesManager.TableStyles("Legacy Revision Table")
	oTableTitle = oActiveTableStyle.Title
	oCTable.Style = oActiveTableStyle
Next
End Sub
