San,
I've tried this code in a .ivb
When I open New.idw, it's still looking for Old.ipt?
Thx, CVA
NewIDW = "c:\new\New.idw"
OldIPT = "c:\old\Old.ipt"
NewIPT = "c:\new\New.ipt"
Dim oApprentice As New ApprenticeServerComponent
If oApprentice Is Nothing Then
Set oApprentice = New ApprenticeServerComponent
Dim oAdoc As ApprenticeServerDrawingDocument
Set oAdoc = oApprentice.Open(NewIDW)
Dim oRefFileDesc As ReferencedFileDescriptor
'Set oRefFileDesc = oApprentice.Document
For Each oRefFileDesc In oAdoc.ReferencedFileDescriptors
If oRefFileDesc.FullFileName = OldIPT Then
Call oRefFileDesc.PutLogicalFileNameUsingFull(NewIPT)
Exit For
Next oRefFileDesc
Dim oFileSaveAs As FileSaveAs
Set oFileSaveAs = oApprentice.FileSaveAs
Call oFileSaveAs.AddFileToSave(oAdoc, oAdoc.FullFileName)
Call oFileSaveAs.ExecuteSave
Set oApprentice = Nothing
www.CVAengineering.com
IV11 Pro. sp2
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 84.26
SpacePilot V 1.1.2
"Sanjay Ramaswamy (Autodesk)" wrote in
message news:5582576@discussion.autodesk.com...
In Inventor, you will need to copy the files and fix up the references using
the FileDescriptor.ReplaceReference method. In Apprentice, the FileSaveAs
object automates the fixing up of references, but this is not available in
Inventor. The other option is to spawn off an Apprentice process (outside of
Inventor's process), and perform the file copy.
Sanjay-
"CVAengineering" wrote in message
news:5581527@discussion.autodesk.com...
Without using Apprentice Server, is there a way to copy files using AddIn
and maintain the link between the idw and ipt/iam
Thx, CVA
IV11 Pro. sp2
Window XP Pro sp2
SpacePilot V 1.1.2
