Copy Design
Copy Design
Copy Design
Hi ADG>AI>AIC
It should be a simply question but I'm not an expert in Inventor API so I need your help.
I have an assembly. It is composed by one IAM containing a number of parts with linked Excel spreadsheet and I need to simulate the Copy Design command via the Inventor API.
My command should:
1 ask the name of the new project
2 save files into a new directory (like Copy Design) but automatically without asking the new name of each file
3 copy the excel and set the name of variables in excel
4 open each part/iam and change the referenced excel in each new file.
Could someone give the right start for points 2 and 4? or where do I find some helpful info?
Thanks in advance.
Have a nice weekend,
Mario
xiaodong_liang
Autodesk Support
Autodesk Support
I may still at the initial stage of understanding on your question, but I'd like to recommend this nice tool. It can copy design  Inventor IAM/IDW/DWG file along with any files it references (including substitute parts and OLE references). And it provides source code.
http://labs.autodesk.com/utilities/hierarchyclone/
Yes, it's exactly what I need and good starting point for my apps.
Thank you very much.
Bye,
Mario
HogueOne
This link appears to be broken. Is there another way I can access the source code?
