Copy Design - Reset File Save Counter
I've noticed that when a part file copy design is performed the FILE SAVE COUNTER isn't reseted, it continuous with the value that the copied part had.
Is there any chance to change this vault caracteristic and reset this counter?
Explaining why I need this.
- I've created an ilogic rule that deletes / resets some Autodesk Inventor iproperties when a "SAVE AS" operation is done. The purpose is to avoid human error, and avoid that obsolete values are kept on those iproperties fields.This rule checks the FILESAVECOUNTER is equal to [0] or [1]. If that's the case, the mentioned iproperites fields are reseted.
- However, if the new pat is created thru a COPY DESIGN process on VAULT, the FILESAVECOUNTER isn't reseted, and keeps the same value on the original part. This is a problem on my plan, becuase I only solve half problem.
Hope I made myself clear and that some you can help me finding a solution to this.
Best Regards,
Marco
