Copy Design - ilogic Assembly
Hello
I have a project with a vb interface feeding parameters to an ilogic assembly & it’s ok.
However I want another. Not an ilogic copy. Not an assembly with different sizes or parts.
I’d like an independent copy – which I can then redesign some of the parts.
How do you copy a vb.net project?
So far I have started a new project then used copy & paste to add the form & code from the working model – then edit the name to match the new model.
The new model can find the new .dll but the parameters added via the vb interface are not being passed to the model.
Any advice or comment welcome.
Cheers
MES
MjDeck
Can you give more details to explain this?  Maybe you can zip up the Visual Basic project and post it (I mean the copied version of the project)?
Mike Deck
Software Developer
Autodesk, Inc.
