Copy Custom Parameters from one .ipt to Multiple.ipt's (Existing Files)
RockyBrown4134
Message 1 of 24
RockyBrown4134
Is ther a way to copy parameters from one part file to multiple part files? I have two parameters that I would like to add to multiple files at once.
The Example below, Cutlength already existin in the part files. I want to add the parameters FT and IN. My ultimate gole is to have feet and inches displayed in my parts list.
Thanks.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Accepted solutions (3)
Replies (23)
Message 21 of 24
tjvz85
Hi @Curtis_Waguespack ,
Would it be possible to adjust the Select Parts File rule to have a window select option, to pick parts right from the open assembly, or browser?
Message 22 of 24
Curtis_Waguespack
Hi @tjvz85
The batch file in this thread is a part file, but assuming you've copied the rules and form from that file to an assembly file and have all of that working, you could use this example or something similar for the selection rule.
I hope this helps.
Curtis
Sub Main
Create_Params()
Select_Files()
End Sub
Sub Create_Params()
' Get the active document.  Assumes a part document is active.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
' Get the UserParameters collection
Dim userParams As UserParameters
userParams = oDoc.ComponentDefinition.Parameters.UserParameters
'check for parameter and create if not found
Try
	oTest = Parameter("Part_Files_List")
Catch
	'multi-value text parameter
	userParams.AddByValue("Part_Files_List", "< No Files >", UnitsTypeEnum.kTextUnits)
End Try
Parameter.Param("Part_Files_List").IsKey​ = True
Try
	oTest = Parameter("ActionList")
Catch
	userParams.AddByValue("ActionList", "Copy All Custom Parameters", UnitsTypeEnum.kTextUnits)
	MultiValue.SetList("ActionList", "Copy All Custom Parameters", "Delete All Custom Parameters")
End Try
Parameter.Param("ActionList").IsKey​ = True
End Sub
Sub Select_Files()
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveEditDocument.ComponentDefinition
Dim oPart As ComponentOccurrence
Dim oHighLight As Inventor.HighlightSet
oHighLight = ThisDoc.Document.CreateHighlightSet
Dim oSelect As ComponentOccurrence
Dim oNamesList As New ArrayList
Dim oPrompt1 As String
oPrompt1 = "Select components, then press Escape to continue..."
While True
	oSelect = ThisApplication.CommandManager.Pick _
		(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, oPrompt1)
		'if nothing then exit
	If IsNothing(oSelect) Then Exit While
	oNamesList.Add(oSelect.Definition.document.fullfilename)
	Call oHighLight.AddItem(oSelect)
End While
'define ArrayList to hold each file name
Dim MyArrayList As New ArrayList
'add existing parameter list items to the array
For Each Item In MultiValue.List("Part_Files_List")
	If Item <> "< No Files >" Then
	MyArrayList.Add(Item)
	Else
Next
'Loop through result strings with For Each.
Dim sFile As String
i = 0
For Each sFile In oNamesList
'check for duplicates then
'add selected files to the array
If Not (MyArrayList.Contains(sFile)) Then
	MyArrayList.Add(sFile)
Else
'add to counter for each duplicate file
i = i +1
Next
'add the array to the parameter list
MultiValue.List("Part_Files_List") = MyArrayList
Parameter("Part_Files_List") = myArrayList(0)
If i >0 Then
MessageBox.Show("Note: Duplicate file(s) not added to the list.","iLogic", _
MessageBoxButtons.OK,MessageBoxIcon.Information)
End Sub
Message 23 of 24
tjvz85
Thanks so much @Curtis_Waguespack ,
We have taken it all and converted to a global form, to run external rules. The Select Part Files routine adds the parameter needed for the batch rule to run and then we proceed from there.
Thanks so much, will test and let you know how it works.
Message 24 of 24
tjvz85
Works like a charm, thanks again.
