COPY CUSTOM IPROPERTIES FROM PARENT ASSY TO CHILDREN ASSY
_bmiller_
Message 1 of 10
_bmiller_
I need to copy all custom iproperties from main assembly to all lower assemblies in it. if they are not there then add them. been beating my head against the wall with this one. I'm missing something that should be easy to do.
Replies (9)
Message 2 of 10
gerrardhickson
Can you post the code you have so far?
Message 3 of 10
FINET_Laurent
Hi @_bmiller_,
Here is a sample code of mine that would loop through each occurences of an assembly (top node only) and add the custom iProperties of the assembly the rule is fired from. If a property already exists, it skips it, preventing errors & override :
Dim doc As Inventor.AssemblyDocument = ThisApplication.ActiveDocument
Dim acd As Inventor.AssemblyComponentDefinition = doc.ComponentDefinition
For Each p As Inventor.Property In doc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
	For Each occ As Inventor.ComponentOccurrence In acd.Occurrences
		Dim occDoc As Inventor.Document = occ.ReferencedDocumentDescriptor.ReferencedDocument
		Dim cpset As Inventor.PropertySet = occDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
		Dim exist As Boolean = False
		For Each op As Inventor.Property In cpset
			If op.Name = p.Name Then
				exist = True
				Exit For
		Next
		If exist = True Then Continue For
		cpset.Add(p.Value, p.Name)
	Next
Next
Does this suits your needs ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 4 of 10
FINET_Laurent
@_bmiller_ ,
Reading twice, I'm not so sure about your question. Do we have to copy the iProperties only to sub assemblies, or are parts included ? What is the sub assembly has sub-assemblies ? Do we also consider them ?
If we say yes to all questions, here would be the code :
	For Each occDoc As Inventor.Document In doc.AllReferencedDocuments
		If occDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
				exist = True
				Exit For
		Next
	Next
Next
Kind regards,
FINET L.
Message 5 of 10
FINET_Laurent
@_bmiller_ ,
And finally, if we only want to consider the top nodes sub-assemblies, here would be the code :
		If occDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
				exist = True
				Exit For
		Next
	Next
Next
Kind regards,
FINET L.
Message 6 of 10
_bmiller_
this is what i got so far
' Get the main assembly document
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get the custom properties of the main assembly
Dim oMainPropSet As PropertySet
oMainPropSet = oAsmDoc.PropertySets.Item("Inventor User Defined Properties")
' Iterate over all the sub-assemblies
For Each oSubAsm In oAsmDoc.AllReferencedDocuments
    ' Skip if the referenced document is not an assembly
    If oSubAsm.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        Continue For
    ' Get the custom properties of the sub-assembly
    Dim oSubPropSet As PropertySet
    oSubPropSet = oSubAsm.PropertySets.Item("Inventor User Defined Properties")
    ' Iterate over all properties in the main assembly
    For Each oMainProp In oMainPropSet
        ' Check if the property exists in the sub-assembly
        Dim oSubProp As [Property] = Nothing
        Try
            oSubProp = oSubPropSet.Item(oMainProp.Name)
        Catch ex As Exception
            ' Property doesn't exist, do nothing
        End Try
        ' If the sub-assembly doesn't have the property, add it
        If oSubProp Is Nothing Then
            oSubPropSet.Add(oMainProp.Value, oMainProp.Name)
        Else
            ' If the property exists, copy the value from the main assembly
            oSubProp.Value = oMainProp.Value
    Next
Next
, it works for the most part but i get unspecified errors sometimes and cant find the error
Message 7 of 10
FINET_Laurent
Hi @_bmiller_,
By looking at the code you provided us, I can see that you are using try/catches. I would rather use a small check with a loop in the properties to see if we find a match, than intentionally firing an exception. The code I posted above in my thrid post accomplish the exact same as your, with the small improved I'm explaining right now.
Can you test it out and give us feed back?
Thank you & kind regards,
FINET L.
Message 8 of 10
_bmiller_
Just tried it but nothing copied down.
Message 9 of 10
FINET_Laurent
@_bmiller_,
I just found a small error on line 7. It was different instead of equals. Fixed it :
				exist = True
				Exit For
		Next
	Next
Next
Kind regards,
FINET L.
Message 10 of 10
_bmiller_
That does first layer only, small mod will catch lower layers as well.
thanks
