Copy components and assembly
ngowans
ngowans
I have an iLogic assembly of a handful of sheetmetal components which are driven by an Ilogic form. So far this all works brilliantly. However I would like to make a script which saves a copy of the assembly and all of it's constituent parts into a specific folder at the click of a button and ensures they retain their relationships. In the process I would like to remove all the ilogic scripts and forms as well as supressed components from the top level assembly so I have a more or less static record of a specific configuration of the assembly.
So far my manual workflow involves the following.
1 - Using my form I set my geometry to whichever specific arrangement I need.
2 - This sets the part numbers of all components correctly based on their geometry.
3 - I then click "copy" within the pattern menu in the assembly.
4 - I select all parts by selecting the top level of the assembly in the browser. This normally ignores anything supressed and reuses any design centre parts
5 - I select next, then select "create new assembly"
6 - I then rename all my parts with a suitable suffix in this case P-001
7 - I create a folder by choosing workspace and then typing \P-001
Clicking ok creates the appropriate files in the appropriate folder and all is good, however I want this process to be fully automatic based on the part number of the top level assembly or the value of an arbitrary custom iproperty (or maybe even a parameter) and function with the click of a single button for any future assembly arrangement.
 So far I am able to create my folder automatically based on whether a suitably named folder already exists in the appropriate location. But I haven't found anything which will do the actual saving and rereferencing of the files in an appropriate way. They normally just refer to the master file which is no good. Anything I find online just seems to want to refer me to ilogic design copy.
Can anyone help?
dalton98
This should be what your looking for. You will have to manually delete the forms.
'create folder in project file
Dim IPJ As String
Dim IPJ_Name As String
Dim IPJ_Path As String
Dim FNamePos As Long
IPJ = ThisApplication.FileLocations.FileLocationsFile
FNamePos = InStrRev(IPJ, "\", -1)
IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4)
IPJ_Folder_Location = Left(IPJ, Len(IPJ) -Len(IPJ_Name))
Dim oFolder As String
oFolder = IPJ_Folder_Location & "P-001\"
If System.IO.Directory.Exists(oFolder) = False
	System.IO.Directory.CreateDirectory(oFolder)
'copy current assembly
Dim oAss As AssemblyDocument
oAss = ThisApplication.ActiveDocument
Dim newAss As String = oFolder & System.IO.Path.GetFileNameWithoutExtension(oAss.FullDocumentName) & "-P-001.iam"
oAss.SaveAs(newAss, True)
'open new assembly
Dim oAssNew As AssemblyDocument
oAssNew = ThisApplication.Documents.Open(newAss, True)
'go through each component in the assembly, copy, replace
Dim oOcc As ComponentOccurrence
For Each oOcc In oAssNew.ComponentDefinition.Occurrences
	If oOcc.Suppressed = False
	Dim oDoc As Document
	oDoc = oOcc.Definition.Document
	If oDoc.DocumentType = kPartDocumentObject
		Dim newDoc As String = oFolder & System.IO.Path.GetFileNameWithoutExtension(oDoc.FullDocumentName) & "-P-001.ipt"
		Try
		oDoc.SaveAs(newDoc, True)
		Catch
		End Try
		oOcc.Replace(newDoc, False)
Next
iLogicVb.Automation.DeleteAllRulesInDocument(oAssNew)
1830108CDDDF
Hi @dalton98, I've just found this thread, the code you posted seems to work pretty well in the top level of the assembly, it could be modified in a way that works with everything involved in the assembly? E.g. Sub-assemblies and its parts.
Thanks in advanced, greetings!
dalton98
@1830108CDDDF Hello. This is sloppy and not well written so you would probably be better off creating a new topic haha(was fairly new to ilogic).
If you want the reach sub assemblies you would need to create a recursive sub routine that would loop through each component  ex.
Sub Main
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Call RecursiveOccurrences(oADoc.ComponentDefinition.Occurrences)
End Sub
Sub RecursiveOccurrences(oOccs As ComponentOccurrences)
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.Definition.Document.DocumentType = kAssemblyDocumentObject
			'loop through each sub occurrence
			Call  RecursiveOccurrences(oOcc.SubOccurrences)
		ElseIf oOcc.Definition.Document.DocumentType = kPartDocumentObject
			'do  stuff
			'MessageBox.Show("Message", "Title")
			'Return
	Next
End Sub
