Copy an assembly with ApprenticeServer 2022
marin_israel
Message 1 of 1
marin_israel
Hello, I have an executable that copies assemblies with ApprenticeServer that has worked very well since 2010. But, with the arrival of ModelStates in 2022, it no longer works. For 2 weeks, I've been struggling to find a solution. I have identified several elements to modify but the task is very difficult and my addIn no longer works, which is very stressful. I need help identifying with more confidence what I need to correct to get my AddIn back on its feet. The executable is an essential gear of my addIn. I provide you my code and I hope to be able to find a solution quickly with your advice. If you need any informations, be sure I will provide it shortly.
My main problem is with sub-assembly references. Links only change for the current ModelState. For my project, the assemblies have parts and subassemblies suppressed and everything needs to be copied to either my factory model state or my custom model state. Since the ApprenticeServer does not support model state. I don't know how to correct the situation.
Thanks!
Israël Marin
Programmeur | Programmer
Logiflex
Replies (0)
