converting Autocad bas to Inventor
What is the equivalent of ThisDrawing as used in AutoCAD
I have tried ThisDocument, and ThisApplication.ActiveDocument but they don't seem to
work
This is the line it hangs on with a Object doesn't support this property or method.
DlgName.hwndOwner = ThisDrawing.HWND
Kent Keller
http://kwik-mcad.scriptmania.com/
Hi Kent,
The ThisDocument object only works in the macro "built in" to each document.
Inventor exposes windows handles a bit differently. The main IV window is
exposed through Inventor.Application.MainFrameHWND.
The handle to a particular IV window is exposed as a property of the View
(View.HWND). Because you can have multiple windows of the same document,
there is a views collection. The following simple macro prints out the
windows handle for the Inventor application and the first view of the
current document (using the ThisDocument object in that document's embedded
VBA project).
Public Sub Test()
Dim a As Inventor.Application
Dim b As Double
Set a = ThisApplication
Debug.Print a.MainFrameHWND
b = ThisDocument.Views(1).HWND
Debug.Print b
End Sub
Cheers,
Neil
"Kent Keller" wrote in message
news:ACEDCB121ED04AEF666D3DC621D88739@in.WebX.maYIadrTaRb...
don't seem to
> work
or method.
> Kent Keller
Thanks Neil
The MainFrameHWND appears to be what it needed.
Kent Keller
"Neil Munro" wrote in message
news:CCDFE0A6F64DEAC51E921380423CFF7B@in.WebX.maYIadrTaRb...
> Hi Kent,
> VBA project).
> Public Sub Test()
> Dim b As Double
> Debug.Print b
> End Sub
> Cheers,
> Neil
> don't seem to
> > work
> or method.
> > Kent Keller
