Convert string into double
18154093
18154093
Hi guys
I need convert string into double
ex: 1/12 => 0.8333
g.georgiades
If you don't have a fraction symbol - you can use double.Parse
Double.Parse(".523")
Double.Parse("-0.523")
For fractional formats, I found two options:
You can have a look at this post where inventor UOM is used to convert the value. You may have to experiment with the units.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/convert-fraction-to-decimal/m-p/9751...
For a purely code solution see this stackoverflow post. I have converted the c# to vb.net/iLogic code for you
https://stackoverflow.com/questions/13903621/convert-a-text-fraction-to-a-decimal
Private Function FractionToDouble(ByVal fraction As String) As Double
        Dim result As Double
        If Double.TryParse(fraction, result) Then
            Return result
        Dim split = fraction.Split(New Char() {" "c, "/"c})
        If split.Length = 2 OrElse split.Length = 3 Then
            Dim a, b As Integer
            If Integer.TryParse(split(0), a) AndAlso Integer.TryParse(split(1), b) Then
                If split.Length = 2 Then
                    Return a / b
                Dim c As Integer
                If Integer.TryParse(split(2), c) Then
                    Return a + b / c
        Throw New FormatException("Not a valid fraction.")
End Function
WCrihfield
Hi @18154093.  This is what I had in mind for your challenge.  Inventor's built-in UnitsOfMeasure object has many useful tools for things like this.  Also, I just assumed you were working with inches, but if that is not the case, you can change those aspects within the code.  The database units for length are centimeters, and it seems like very few people actually use that as their default document units.
Dim oStVal As String = "1/12"
Dim UOM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Dim oDblVal As Double = UOM.GetValueFromExpression(oStVal, "in")
oDblVal = UOM.ConvertUnits(oDblVal, "cm", "in")
MsgBox("oDblVal = " & oDblVal,,"")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
