conversion of idw to dwg
I have a few inventor drawings and i want to export them to autocad dwg such that the linework, dimensions and text pick up the right corresponding layers in autocad and are also coloured. how to achieve this?
is there a good tutorial to explain the export dwg options in detail?
WCrihfield
Here are a couple of links you might find helpful.
To Export Data to DWG
Inventor -> dwg export and line weights
Save as DWG Translator Sample API Sample
DWG export settings
Wesley Crihfield
(Not an Autodesk Employee)
