Controlling the camera using Ilogic
Hi There,
I am looking for a way to create a turntable of my model using I logic.
The code I already have is a mix of multiple forum posts. but I can't get it to work.
Can I get some help on this.
I want to rotate the view around the Z axis from the starting point where the camera is.
When using this code, The camera goes first to a certain point and I don't know where that is.
The final output for the app wil be a html turntable to put on websites.
Thanks in advance.
   ' Get the active camera.
Dim cam As Camera
cam = ThisApplication.ActiveView.Camera
Dim tg As TransientGeometry
tg = ThisApplication.TransientGeometry
   ' Define the number of steps in the animation.
   Dim steps As Integer
   steps = 40
   ' Iterate the specified number of steps.
   Dim i As Integer
   For i = 1 To steps
cam.Fit()
cam.Perspective = 0
cam.ViewOrientationType= 10764
'cam.UpVector = tg.CreateUnitVector(0, 0, 0)
cam.Eye = tg.CreatePoint(0,i,0)
     cam.ApplyWithoutTransition
   Next
Hi
Here is a VBA sample that rotates the model dynamically of 360 degrees around Y axis:
Public Sub RotateCamMacro()
    Dim pi As Double
    pi = Math.Atn(1) * 4
    'Rotation speed in Rad/Sec
    Dim rotSpeedRad As Double
    rotSpeedRad = 40 * pi / 180
    'Get part document
    Dim doc As Document
    Set doc = ThisApplication.ActiveDocument
    'Get range box center point
    Dim centerPoint As point
    Set centerPoint = GetRangeBoxCenter(doc)
    'Set camera orientation
    Call SetCameraOrientation( _
        centerPoint, _
        ViewOrientationTypeEnum.kIsoTopRightViewOrientation)
    'Get Inventor camera
    Dim camera As Inventor.camera
    Set camera = ThisApplication.ActiveView.camera
    Dim totalRot As Double
    totalRot = 0
    Dim offsetRad As Double
    Dim rotAxis As vector
    Set rotAxis = ThisApplication.TransientGeometry.CreateVector(0, 1, 0)
    Dim upVector As UnitVector
    Set upVector = ThisApplication.TransientGeometry.CreateUnitVector(0, 1, 0)
    Do While (totalRot < 2 * pi)
        offsetRad = 0.05 * rotSpeedRad
        RotateCam camera, offsetRad, rotAxis, centerPoint, upVector
        totalRot = totalRot + offsetRad
    Loop
        centerPoint, _
End Sub
Public Function GetRangeBoxCenter(ByVal doc As Document) As point
    Dim minPoint As point
    Set minPoint = doc.ComponentDefinition.RangeBox.minPoint
    Dim maxPoint As point
    Set maxPoint = doc.ComponentDefinition.RangeBox.maxPoint
    Set GetRangeBoxCenter = ThisApplication.TransientGeometry.CreatePoint( _
        (minPoint.X + maxPoint.X) * 0.5, _
        (minPoint.Y + maxPoint.Y) * 0.5, _
        (minPoint.Z + maxPoint.Z) * 0.5)
End Function
Public Sub SetCameraOrientation( _
    ByVal targetPoint As point, _
    ByVal viewOrientation As ViewOrientationTypeEnum)
    camera.ViewOrientationType = viewOrientation
    camera.target = targetPoint
    Call camera.Fit
    Call camera.ApplyWithoutTransition
End Sub
Public Sub RotateCam( _
    camera As camera, _
    ByVal offsetRad As Double, _
    rotAxis As vector, _
    center As point, _
    upVector As UnitVector)
    Dim matrix As matrix
    Set matrix = ThisApplication.TransientGeometry.CreateMatrix
    Call matrix.SetToRotation(offsetRad, rotAxis, center)
    Dim newEye As point
    Set newEye = camera.eye
    Call newEye.TransformBy(matrix)
    camera.eye = newEye
    camera.upVector = upVector
End Sub
Philippe.
Hi Philippe,
This will get me going, great sample !
I will post further development codes.
Thanks.
