Controlling Subfolders in Browser Tree
Schredhammer
Schredhammer
In the attached image I have my main folder "Elements" and then each subfolder for our different heating elements. I just can't figure out how to tell iLogic to turn on/off those subfolders. Is it possible to control subfolders?
mcgyvr
What exactly do you mean by "to turn on/off those subfolders"?
Are you wanting to suppress the parts inside the folders? Turn visibility of those parts on/off? Something else?
Schredhammer
At the moment, just turn their visibility on/off.
fidel.makatiaD5W7V
Hi @Schredhammer , check out this official docs from inventor
Inventor 2022 Help | Browser Nodes | Autodesk
You can make use of the visible parameter to turn off a node.
for example
node1.visible=false
Fidel Makatia
Developer Advocate
href=https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-0BD48573-7193-4285-87B7-6727555D053E rel= "noopener noreferrer">Inventor 2022 Documentation |
